george findlay
Our salt levels are extremely high, and hardness (hardness 5820 mg/L, sodium 4150 mg/L, TDS 19,400). We have a whole house RO system that cannot deal with this brackish water, unless membranes are changed frequently, at $800 a pop. We also have a water softener that just get confused by all the salt....so service disconnected it. Prevailing wisdom is not to drill a new well as chances are we hit same water pocket. Shallow well not a possibility due to terrain. Town water out the question. The well is 300 ft deep, 50 above sea level…we are 500 ft from the ocean. The idea has come up to do a salination test of well at different levels that may, or may not, indicate fractures producing good/bad water, and depending on results try to isolate salt water by inserting a bladder/packer, then testing water above. If this water tests good and is of sufficient quantity, then the bladder is removed and well sealed up to that height. So that’s the theory, and a couple of well specialists…not in our area….seem to suggest it can work. However, a query posted to an academic (professor of hydrogeology/hydrology) did not encourage….
…Saltwater intrusion is a growing problem along coastal areas, aggravated by global climate change/sea level rise and increased use http://pubs.usgs.gov/circ/2003/circ1262/ The well-packer process you propose would, in my opinion, only be a temporary solution, if it worked at all. The issue is likely the aquifer and not just your well….Saltwater intrusion has contaminated your well, and I see little hope of reclaiming it. I spoke with a colleague about your situation and we share the same opinion.
Any thoughts on this….i hesitate throwing money at expensive testing/engineering if this is not a proven system (ps someone said this is being done now in Pennsylvania fracking industry). Another hope…collecting rainwater and dumping into a cistern…we do have a v. large roof
