Can tube and shell (pool) heat exchangers be used for potable applications?
james b
Washington
I have an application where I want to use a heat exchanger. The heat exchanger will exchange heat between the boiler return and the water heater inflow. I want to use a shell and tube heat exchanger also known as a pool heat exchanger because of the lower psi loss and because I can spare the space. I realize that brazed plate heat exchangers are more commonly used for this application. I have not been able to get a definitive answer regarding weather or not shell and tube heat exchangers are rated for potable water.
Does anyone have any information regarding pool heat exchangers and potable water?
http://www.brazetek.com/
Regards
James
Seattle, WA
Save-H2O
Vancouver, Washington
Regards
James
Seattle, WA
I don't believe so since it's considered a cross connection with non potable water. In addition the system will need a rpba backflow assembly which will drop your pressure.
quote; I don't believe so since it's considered a cross connection with non potable water. In addition the system will need a rpba backflow assembly which will drop your pressure.
What does ANY of this have to do with the question? He is merely asking if a "pool type" heater can be used for heating domestic water, and normally the answer would be yes.
