Can someone recommend a toilet
Discussion in 'Toilet Forum discussions' started by xnaron, Jan 30, 2008.
  1. xnaron
    xnaron New Member
    Jan 28, 2008
    Alberta
    Can someone recommend a good toilet that meets the following criteria.
    1. installing in a basement on concrete slab (needs to push enough water so it won't back up)
    2. at least 6 litres per flush (no ultra low flushers)
    3. need to be able to buy it regular stock at stores like HD
    Bascially I'm just wanting to be sure I don't buy a lemon. Don't want to have to install it more than once.
    thanks,
    Brendin
    Was looking at the Crane Hymont II 16 In. High Elongated Toilet Bowl, White at HD
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Probably the American Standard Cadet 3 would be a reasonable choice. You do limit your choices if you insist on shopping the Big Box Stores, much of their stock is what is referred to as "builder grade". These are cheap toilets that builder buy to put in the spec homes and are known for their poor flushing qualities. If you can broaden your shopping scope, a Toto Drake would be an excellent choice.
    Toilets
  4. jadnashua
    The toilets that get recommendations are Toto Drake, AS Cadet 3, and a few others mostly from Toto. SPend some time reading here, search the toilet test info on the home page.
    Toilets
  5. xnaron
    xnaron New Member
    Jan 28, 2008
    Alberta
    ok...found a Toto Drake at a local shop...going for that...thanks guys.
    Brendin
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    Excellent choice. You'll be happy with it.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Of course when the word gets out the neighbors will be coming over to see that monster flush!
  8. xnaron
    xnaron New Member
    Jan 28, 2008
    Alberta
    Who ever could of thought I'd be excited over a toilet :p
  9. prashster
    prashster New Member
    Dec 7, 2005
    I share your excitement. The toilet inventor was a genious: siphons out the waste and then refills at precisely the right time/rate to refill and block gasses. It makes the dirtiest part of human living clean and elegant.
    Toilet gets my vote for most ingenious appliance in the house.
Similar Threads: someone recommend
Toilet Forum discussions Can someone help me with what type of toilet flange I should get? (see pics) Jan 3, 2011
Toilet Forum discussions Need recommendation for toilet please Mar 18, 2017
Toilet Forum discussions Toilet recommendation for narrow space Dec 26, 2016
Toilet Forum discussions Recommendation for best wall mounted toilet with tank in the wall... Oct 6, 2016
Toilet Forum discussions 2 piece toilet recommendation Oct 4, 2016
