Can someone help identify the cartridge brand/model? Moen Posi-Temp
Discussion in 'Shower & Bathtub Forum & Blog' started by tr1006, Jun 23, 2012.
  1. tr1006
    tr1006 New Member
    Jun 23, 2012
    Denver, Co
    Seems my son snapped off the connector to the unit. So, need a new cartridge and internal parts? Could someone tell me what brand this unit is please :)
  2. Terry
    Aug 17, 2004
    The Moen Posi-Temp shower fixture takes the 1222B cartridge.
    [​IMG]
    Moen replacement 1222 for the Posi-Temp Shower Valve
  4. hj
    UNfortunately, the piece you need in order to "easily" remove it, is what broke off. I am not sure how YOU are going to extract the remainder, but do NOT do anything that will damage the brass body or you will be replacing the entire valve. I have some speciallized tools to solve a situation like that, but you do not and it would be cheaper to hire a "good" plumber than buy them. At least your cartridge is intact. The last one I had to remove the customer had already destroyed it before calling me which made it even more difficult than normal.
  5. Towers Plumbing
    Towers Plumbing In the Trades
    Nov 13, 2012
    Salt Lake City, UT
    A 2x4, 2 3" wood screws.
    Put the wood screws through the 2x4 as close to the center of the cart as you can get in the north and south position in the meaty part of the plastic. Use leverage and pull 2x4 and cart straight out. You might have to twist the cart left and right to break the hard water build up before you pull.
    FYI, we use this as a last option resort when the home owner has screwed up the valve like this. If you are unsure, call a professional.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Be careful when using the "pull hard" approach. I have seen the valve come loose in the wall, which for one unlucky fellow resulted in the backer-board and tile being damaged when it let loose.
Similar Threads: someone help
Shower & Bathtub Forum & Blog Praying someone finds this helpful Nov 21, 2012
Shower & Bathtub Forum & Blog Danze 5020-57, Can someone ID this valve and help me fix it? Aug 22, 2010
Shower & Bathtub Forum & Blog Can someone tell me who the manufacturer of this valve is by these pictures? Jan 20, 2016
Shower & Bathtub Forum & Blog Can someone suggest a good shower valve and explain pressure balance vs thermostatic May 5, 2010
Shower & Bathtub Forum & Blog Can someone tell me how to remove this handle? Aug 16, 2007
