DavidTu
Help: have to choose lesser of two evils slope or structure....
2x8 joist space coming off tub drain we have 1-1/2" CI ptrap as high as possible with plastic street sanitee going direct into ptrap via 1-1/2x2 Fernco proflex coupling. windows in wall below so running horizontal in joist space thru 2x8 header heading off a joist to make room for tub drain. Didn't want to run thru header twice (maybe wrong decision)--once for drain, once for vent) so vented to wye on horizontal before the header on an (honestly) not quite 45-deg roll. This vent wiggles thru two 45s making back to the wall. To keep these fittings at or below floor level determined my altitude for the run. After wye to vent, it runs about 5' to 90 horizontal turn (combo connecting into shower and laundry 2" horizontal line) and thru joist. This is where we get in trouble on slope. Choosing to keep the run thru 3 joists (2.5" hole) above bottom 2" of joist as per code and to keep structural integrity has put my entire slope after header less than 1/4" & at points just over 1/8"--going by 8" torpedo which is all will fit in there. This is all in 2nd floor joist so in the end there is a nice drop into 3" pipe going to basement, in case that helps.
Holes are already done, of course. Now what? Better to live with less slope or at this point to make the joist holes worse than they had to be by not only getting within bottom 2" mid span but now also making hole larger than allowable 2.5"(to gain slope) and thus also violate code to bore no more than 1/3 depth of joist (these are ancient actual 7.5" joists btw)??
^^^This is the tub drain, ptrap, wye to vent and thru joist header.
^^^You can see that the first hole is already a bit enlarged, had 1/4 slope coming across but pulled it up higher for cross-joist run.
