Hi,
I am getting conflicting information as to whether PEX can or should be run they same way copper pipes would.
This is for large 6-8,000 sq. ft. custom homes with 30-40 fixtures. One plumber has quoted to run PEX like copper, Teeing off 3/4" risers with 1/2" along the way.
Another plumber says this method may result in inadequate pressure since the I.D. of PEX pipe is much less than copper. The proper way to do it is a manifold system even though it will be more expensive. He also said that PEX is not rated for use with hot water recirculating systems and should not just be looped from the furthest line?
Any comments would be greatly appreciated.
