Can overhead service wire be run inside conduit?
Discussion in 'Electrical Forum discussion & Blog' started by leejosepho, Jun 1, 2008.
  1. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I need to run 50' of wire to carry at least 60 amps (220) to the subpanel in my attached workshop, and the cost of the wire is presently keeping that project on hold. I can get a used length of twisted, 100-amp (outdoor overhead) service wire from a friend for virtually nothing, and I am asking if there is any problem with running that wire through conduit from my basement to the new workshop. I would have to add a 4th strand for the ground, and all of that might fit inside 1" conduit.
    Is there anything saying that particular service wire should not be run inside conduit and through walls?
    Thank you!
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It's probably twisted and will be very hard to pull if there are any bends.
    You should untwist it, use a larger conduit (not more than 40% fill), and get some lubricant. You will also need to have some means to apply more tension than you can apply by yourself, and someone to push on the inlet end.
    Wire in conduit has a lower ampacity than is applied to overhead services applications.
  4. hj
    wire
    It is also probably aluminum with a bare neutral so you have to make provision for it when you connect it.
  5. leejosepho
    Nov 23, 2006
    Can I use four strands of the wire in this picture?
    Here is the auction description:
    #6 AWG STRANDED INSULATED GROUND COPPER WIRE 250' ROLL
    Wire reads: REPUBLIC WIRE 6 AWG TYPE MTW OR THHN OR THWN-2 600V OR GASOLINE AND OIL RES II (UL) OR AWM-VW-1 SUN RES OR C-(UL) TYPE T90 NYLON OR TWN 75 E167613 FT1
    Thank you!
  6. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    FYI - As to the label on the package and it saying "Ground Wire", the Andrew company sells large satellite and microwave dishes which require grounding. Thus I think they are "repackaging" this wire and calling it ground wire.
    Here is their info on this...
    http://awapps.commscope.com/catalog/product_details.aspx?id=361
  7. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    No to both questions
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I agree with Mike, what your propose is a violation.
  9. hj
    garage
    As an aside, your garage will probably have a subpanel and that should be grounded with a ground rod, not necessarily a ground wire back to the original panel.
  10. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    ground rods are for lightning protection, not the ground your talking about. Oh, and attatched buildings with sub-panels do not require ground rods, but they do require 4 wires.
  11. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Why dont you just go buy some 2/3 SER cable? good for 90 amps, or some 4/3 SER cable good for 65 amps. that wire is not that expensive.
  12. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    MAN, the 2008 NEC SUCKS!
  13. Speedy Petey
    Jun 16, 2007
    NY State, USA
    +1 .............
  14. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Actually, # 4 would only be good for 55 amps under the 2008, glad we are not using it. :D
  15. jimbo
    jimbo Plumber
    San Diego, CA
    To be specific, that ground wire does not carry an insulation rating which would allow you to use it for "hot" conductors. It may be perfectly fine, but it is not rated...so don't use it.
  16. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Oh, I thought you were referring to copper. :(
  17. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    No, sorry, my mistake for not specifying. Either way, i agree with your feelings toward the 2008 changes.
  18. leejosepho
    Nov 23, 2006
    Yes. I see, and that answers at least some questions I had. Thank you.
    I do not know what SER cable is, but I will find out and take a look. There is a very reputable supply house nearby where I can get a contractor's price through my employer.
    I did some homework on the auction wire and I believe it might be okay (including the temperature rating) if the conduit is sized properly and I color-code the four strands, but I will not likely spend the time to first be absolutely certain about all of that unless cost becomes a really big issue.
    Thank you.
  19. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    This is SER type cable
    http://www.southwire.com/ProductCatalog/XTEInterfaceServlet?contentKey=prodcatsheet273
    Unless that "free wire" is a Chapter 3 wiring method forget about it.
  20. leejosepho
    Nov 23, 2006
    What "free wire", and Chapter 3 of what?
    Question: If I use the SER wire you mentioned, would I still have to run it in conduit?
  21. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    No but you would have to install a messenger wire to support the cable from being pulled on with added weight such as the wind or ice.
    EDITED TO ADD;
    Just though about something and wanted to be clear on the fact that SE-R cable can not be installed underground with or without conduit.
    338.12 Uses Not Permitted.
    (A) Service-Entrance Cable. Service-entrance cable (SE) shall not be used under the following conditions or in the following locations:
    (1) Where subject to physical damage unless protected in accordance with 230.50(A)
    (2) Underground with or without a raceway
Similar Threads: overhead service
Electrical Forum discussion & Blog Overhead Light -- not kitchen, bath or laundry. Apr 15, 2015
Electrical Forum discussion & Blog Help eliminating glare on worktable from overhead fixtures Dec 15, 2012
Electrical Forum discussion & Blog Tap wall switch for outlets to add overhead light? Dec 1, 2011
Electrical Forum discussion & Blog Installing Overhead light, have question. Nov 26, 2009
Electrical Forum discussion & Blog Switched receptacle and overhead light?? Oct 28, 2009
