Can Lights
Discussion in 'Electrical Forum discussion & Blog' started by dmtm21, Feb 5, 2008.
  1. dmtm21
    dmtm21 New Member
    Aug 6, 2007
    I am installing three new 3 inch utilitech recessed lights in my master bath. Two of them will be in the new walk in shower and the other away from the shower. I have read the instructions and cannot find anywhere that is says they cannot be installed in "wet" areas. Should i consider them safe? And they ae non-ic models and was wondering if I could build 1ft by 1ft boxes out of sheetrock and cover them in the attic to protect them from insulation. I would drill a 3 inch hole in the top of each box to allow heat to escape from the boxes? No,no or what do you think?Thanks, Danny
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    They need to be rated damp location for a shower area, wet lcoation if they are subject to shower spray, if they are not listed then you cannot use them... call the manufacture if you have any questions regarding their listing.
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    An electrician on another forum didn't think much of Utilitech:
    "There are some recessed cans out there, all identical, but sold under different brand names. The cans sold under "Cooper", "Commercial Electric", "Emerald", and "UtiliTech" are all the exact same cans. They are among the most time consuming, low quality, miserable cans you'll ever deal with."
    That aside, you may be able to find a trim set and lens for them rated for a damp or wet location. There may be additional restrictions on the bulbs allowed with those trim sets. The can itself only needs to be kept 3" from insulation -- easiest way is probably to roll a circle of sheet metal to a diameter of 6" greater than the OD of the can.
  5. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    Is there any reason you don't want to buy and IC can. I wish you were local. I've got exactly three of them with trim pieces sitting in front of me that I'd sell you for about $8/per.
    Tom
  6. dmtm21
    dmtm21 New Member
    Aug 6, 2007
    Where are you located statjunk? Sounds like a hell of deal!:D
Similar Threads: Lights
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Lights won't turn off, sometimes if switch is halfway Aug 24, 2016
Electrical Forum discussion & Blog Wiring lights in series with switch loop at the end Jun 24, 2016
Electrical Forum discussion & Blog 3 recessed lights, switch at end? May 9, 2015
Electrical Forum discussion & Blog Retrofit Recessed lights with LED Dec 3, 2014
