Can I vent New bathroom vent into dryer vent line?
Discussion in 'Shower & Bathtub Forum & Blog' started by cwolters, Apr 25, 2005.
  1. cwolters
    cwolters New Member
    Jan 7, 2005
    Michigan
    I want to add a ceiling vent to the bathroom. We currently have a washer/dryer setup in the same room just divided by articulating doors. The window that the the dryer vents thru is glass block and to try to avoid tearing that up, is there some way I can tie a bathroom fan vent line into the dryer vent line? I was looking for some type of a check valve or something that would keep the dryer exhaust from going to the fan and untimately into the room. I had figured on using a y instead of a t to help the exhaust head toward the window instead of the new ceiling fan. The next closest window is about 20 feet away and on the other side of a wall plus this is a basement bathroom so the kitchen is directly above so there is not an option to vent up thru the roof as a direct line.
    If It seems possible, what suggestions should I keep in mind>
    Thanks.
    Chris
  2. PEW
    PEW DIY Senior Member
    The reasons against it would go on forever, the reasons for doing it will not exist.
    There is no way to keep from overpowering the bathroom fan.
    There is no way to completely seal off the dryer air from the bathroom.
    If your dryer is gas....
    Debris (fuzz) pushed into bathroom, in spite of the possible built-in damper.
    Bathroom air being pushed into dryer.
    etc.
    Personally I would find some way to exaust the air to the outside directly.
    Paul
  4. cwolters
    cwolters New Member
    Jan 7, 2005
    Michigan
    That is what my common sense tells me as well, but I wanted to make sure there was not a 'check valve' of sorts that would allow me to do that. The dryer is electric, but I understand and had thought of the backflow that is why I just wanted to make sure an item did not exist. The only reason for trying to do it is that the glass block window is in line with a wall. One glass block on the left of the wall that is actually a flap vent for the dryer and the other 3 glass blocks on the right of the wall are actually one half block then a double block wide hopper window then another half block wide glass block. Right now we open the window to let moisture out but I wanted to add a fan for conveience sake.
    I ran across the power vents for dryers so I didn't know if there was such a thing to combine the two vents already in existance but known as a last resort fix.
    Thanks - I guess I will stay with the hopper window for now.
  5. jadnashua
    Which way do the floor joists run? If from where you want to put the fan to the outside wall, then it shouldn't be too bad to run the vent through the ceiling to the outside. If they run the other way, it might still be possible, but it would have to go much further.
Similar Threads: vent bathroom
Shower & Bathtub Forum & Blog Best bathroom vent fan with light? Jun 16, 2016
Shower & Bathtub Forum & Blog Best soffit vent w/ anti-backdraft, for bathroom vent fan? Jun 16, 2016
Shower & Bathtub Forum & Blog Bathroom Exhaust Fan Venting Mar 11, 2015
Shower & Bathtub Forum & Blog Bathroom fan vent path when joists are parallel to wall? Mar 28, 2013
Shower & Bathtub Forum & Blog Any Recent Upadate Info for NuTone vs. Panasonic Bathroom Vent Fans with a light? Oct 7, 2012
