Can I use unused tankless for heating?
Discussion in 'Tankless Water Heater Forum' started by john2129, Aug 4, 2010.
  1. john2129
    john2129 New Member
    Jul 31, 2010
    Retired
    Westborough, MA
    I have a V-1 Burnham boiler with forced hot water heating. The tankless part has never been connected to anything. Can I plub this into my FHW system - I'll test for leaks first.
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    What's the point of using the tankless coil for space heating rather than the boiler itself? The tankless coil's heat exchanger, is not of infinite heat-exchange capacity, but is probably enough to handle moderate space heating loads. It's output capacity will depend on the temp you run the boiler at, which may be a a higher (==lossier, lower efficiency) temp than if running the heating system directly.
  4. john2129
    john2129 New Member
    Jul 31, 2010
    Retired
    Westborough, MA
    Sorry, I was not clear...
    My boiler IS used for FHW space heating. Would it increase heating efficiency if I plumb the unused tankless coil into the space heating system. Thanks for your patience.
Similar Threads: unused tankless
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Bosch us12 tankless Jan 27, 2017
Tankless Water Heater Forum Tankless issues Jan 24, 2017
Tankless Water Heater Forum Enough gas supply to install tankless? Jan 21, 2017
Tankless Water Heater Forum Considering two dual-tankless options - feedback requested Dec 31, 2016
