Can I use "in wall vent" instead of thru roof for shower?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hawksnest, May 17, 2006.
  1. hawksnest
    hawksnest New Member
    May 17, 2006
    I've used an in-wall type vent (air valve) for a toilet before instead of venting through the roof. Would it work for a shower?
    Thanks in advance for your advice.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    There is no "in wall" vent that I know of. There is a vent called an AAV (air admitance valve) that can be used but yuo can not put it in a wall.
  4. hj
    vent
    And at least one vent pipe has to be extended through the roof. You cannot use all AAV's.
  5. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    Oatey, for one, has a wall box with a louvered grate so that you can install it in the wall.
  6. Terry
    Aug 17, 2004
    [​IMG]
    That kind of makes it not sealed up in a wall. This is a box for the wall that has access for replacement, and allows air to get to the AAV.
Similar Threads: wall vent
Plumbing Forum, Professional & DIY Advice Venting question on a double lav on outside wall. Tuesday at 9:13 AM
Plumbing Forum, Professional & DIY Advice Sidewall vent - distance from window/door Feb 23, 2017
Plumbing Forum, Professional & DIY Advice Venting thru sidewall Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Vent and Drain Pipe Cross inside Non-Bearing Wall? Oct 11, 2016
Plumbing Forum, Professional & DIY Advice Plumber wants to run vent stack out gable end of attic wall Jan 25, 2016
