Can I use both the shower & tub ports on a thermostatic valve?
Discussion in 'Shower & Bathtub Forum & Blog' started by STyler, Sep 30, 2009.
  1. STyler
    STyler Member
    Sep 9, 2009
    Rock Hill, SC
    I'm looking at 3/4" thermostatic valves (currently the American Standard R540) and in all applications they show either the shower or the tub port being used with the other port plugged. Is there any reason I can't utilize both ports?
    The application is a horse wash stall. The "shower" port would feed a hose reel ceiling mounted at the center of the stall. I'd like the tub port to feed a separate sillcock. The sillcock will be used for filling buckets to soak hoofs and as a backup for when the hose reel branch is shut down during freezing temperatures.
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    You can use both ports but you will probably find a noticeable water temperature difference.
    The benefit of a thermostatic valve is that you set it a specific temperature and then you don't have to worry about temperature fluctuations but when using both ports you can not guarantee that.
  4. STyler
    STyler Member
    Sep 9, 2009
    Rock Hill, SC
    If I'm only use one or the other, never both at the same time, would it still be an issue? I'd like to set the proper temp for washing the horses (shower port) and mark the handle location then if I use the sillcock (tub port) and adjust the temperature, just return it to the marked position.
  5. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    Yes if your using just one at a time than no problem.
  6. STyler
    STyler Member
    Sep 9, 2009
    Rock Hill, SC
    Thanks for the prompt help. Much appreciated.
Similar Threads: both shower
Shower & Bathtub Forum & Blog How to plumb 3 port diverter for shower, handheld or both Apr 14, 2013
Shower & Bathtub Forum & Blog Diverter how many ports for shower or hand shower, or both May 14, 2012
Shower & Bathtub Forum & Blog Diverter for shower output OR hand-held output but not both Jul 3, 2009
Shower & Bathtub Forum & Blog Hot water in one but not both Showers Jun 12, 2007
Shower & Bathtub Forum & Blog Lack of hot water in both showers Sep 21, 2006
