Can I use a Fernco coupling on this angle?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Austin83, May 18, 2011.
  1. Austin83
    Austin83 New Member
    May 17, 2011
    Sherman, Texas
    I just happend to look under the house and find something that not only made me a little mad, but also made me chuckle. Someone was unable to get two sections of 4" PVC to connect due to a slight angle so they busted out some black duct tape. The section of 4" to the left in the picture is just being cradled by the tape, and it can be lifted up about an inch or so. My question is, can I use a flexible Fernco coupling to make the connection? The only thing going through that section of pipe is water from kitchen and bathroom sink. Any advice is greatly appreciated. Thanks in advance.
    [​IMG]
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Only if you like rodding your drain every other week or so.
  4. hj
    You CAN, but since a Fernco is NOT supposed to be used in that location, because the rubber sleeve can settle just like the duct tape, you should NOT do it, but rather get the pipes into alignment first and then use the proper type of connector.
  5. Austin83
    Austin83 New Member
    May 17, 2011
    Sherman, Texas
    I'll try to find a way to get them lined up. If at a very last resort, how bad would a Fernco coupling be if I built up some support under it to keep it from being suspended? I'm not trying to find an easy way out, I just have limited space to fit under the house and both sides of the pipes are connected making movement limited. This section of the pipe has no solid waste only water from two sinks.
  6. jimbo
    jimbo Plumber
    seems like by definition, because you have a 'peak' in the run, there must also be a 'valley'
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    We can't see everything there is to see, but if it were mine I would cut that entire branch loose to properly support it with hangars, ensuring the entire run was properly pitched.
    It's better to do it right once and never have to worry about it again.
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Aside for the problem of the uneven pipe, you don't seem to understand the type of connection you need. First, if you can get the peak out of it, and if you can a regular PVC couple on the the joint, that would be the best. If the latter is not possible, then the connector to use is NOT a neoprene sleeve with 2 hose clamps. Those are only to be use underground. (buried) The proper connector might be a Fernco BRAND, but would be a banded coupler. These have a wide single band over the entire sleeve. These will hold the joint in line. The first thing you have to do is get the thing straight (sloped away @ 1/4" per foot)
  9. Tom Sawyer
    Nov 29, 2010
    Maine
    There's a coupling on the right side and it appears that the pipe has pulled out of it so even a mission band ain't slipping over the coupling. Cut the mess out and do it right.
Similar Threads: Fernco coupling
Plumbing Forum, Professional & DIY Advice Buried Fernco/Mission coupling - use metal banded or all rubber? Aug 15, 2014
Plumbing Forum, Professional & DIY Advice PVS Repair Coupling VS. Fernco Coupling Apr 20, 2014
Plumbing Forum, Professional & DIY Advice Fernco couplings on pressure pipe Nov 30, 2008
Plumbing Forum, Professional & DIY Advice Fernco coupling failure? May 8, 2007
Plumbing Forum, Professional & DIY Advice Fernco Repair Piece stuck under flange Oct 11, 2016
