Can I tie a washing machine into a bathtub drain line?
Discussion in 'Shower & Bathtub Forum & Blog' started by jonathaninsc, Jul 6, 2012.
  1. jonathaninsc
    jonathaninsc New Member
    Jul 6, 2012
    South Carolina
    Is there any reason I would not want to tie a new washing machine into a bathtub drain as long as I give the washing machine its own P trap? One plumber I spoke with was concerned the force of the washing machine "would suck the water right out of the trap" of the bathtub. Does that sound right? The washing machine is a high efficiency model and uses very little water. Also, can I use an AAV to vent the washing machine?
  2. jadnashua
    EACH trap needs its own individual vent. A tub drain might be as small as 1.5". A washing machine drain needs to be at least 2". So, probably not, but it would depend on how things are layed out. If each trap is properly vented, then, no, neither should siphon the other. Some places do not allow an AAV, so even if it might work, it would not be to code. It is always better to do an atmospheric vent if possible. Keep in mind that an AAV can only let air in, and depending on where it is, sometimes air needs to come out as well.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I believe the question of AAV on a washer was addressed recently, and if I remember correctly, the can not be used for the reason Jim noted on an AAV only letting air in. Also as noted, washers now require a 2" drain.
  5. Terry
    Aug 17, 2004
    It's more about the venting.
    Your plumber has mentioned that water from the washer discharge will suck the tub trap dry.
    If you were to go downline of the tub line, after it has been vented, and then branch off the 2" waste line, with an above floor trap and vent for the washer, that would work. The two should work independent of each other.
    A washer discharges with a pump. Some locations require a 3" line after the 2" trap and trap arm.
  6. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Terry is there not also a certain fall that needs to be realized? I think its something like 36".
    JW
  7. jadnashua
    There's a minimum height of the standpipe, but that is separate from any normal slope once it hits the drain. That height varies based on your local codes.
  8. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    It's the vertical drop of the stand pipe. I think it needs 36" of drop before hitting the PTrap. What is the requirement in New England?
    JW
Similar Threads: washing machine
Shower & Bathtub Forum & Blog Washing machine drain Oct 27, 2015
Shower & Bathtub Forum & Blog Design, connecting shower and washing machine drain to the same sewer pipe. Oct 17, 2010
Shower & Bathtub Forum & Blog Water backup in tubs and toilets when running washing machine, please help!!! May 24, 2005
Shower & Bathtub Forum & Blog shower body machine gun noise Mar 19, 2007
