Can I separate aan ABS fitting?
Discussion in 'Shower & Bathtub Forum & Blog' started by pjb, Mar 13, 2008.
  1. pjb
    pjb New Member
    Mar 13, 2008
    I have a new kitchen sink and would like to replace the wye fitting coming of the sanitary T. It is ABS. I would like to save the T and somehow cut out the short piece that is cemented into the female end on the T. Can this be done without damaging the T fitting? So, I have the T with the drain going down and the vent going up. I need to save that. Connecting the T to the wye is a short piece of ABS. I need to cut that out of the T.
  2. jadnashua
    you can try - cut it off, then cut from the inside, ensuring you don't go into the fitting, and then using s thin screwdriver or something similar try to peel it out of there. Or, buy a drill bit made to ream out a fitting. Depends on angles and access...working under a sink can be a major pain.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    use a "Rambit"
  5. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    The rambit is the easiest bet.
    1 1/2" or 2" fittings are very difficult to do, but it can be done with a hack saw blade , thin screw driver and hammer.. Nothing is impossible. A big factor will be the age of the fittings and how often this drain has seen water temperature changes. The ABS tends to become brittle (glass like) when extreme heat and cooling over an extended period of time are introduced to the pipe and fittings.
    Keep in mind that you run the risk of cracking the sanitary T at the hub.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    If you do try breaking it out fasten an automotive hose clamp around the hub to help keep it from breaking.
Similar Threads: separate fitting
Shower & Bathtub Forum & Blog Mixing valve for shower and separate valve for bathtub Dec 5, 2014
Shower & Bathtub Forum & Blog Separate hot and cold water valves Jan 3, 2013
Shower & Bathtub Forum & Blog Diverter or separate pipes? Apr 28, 2012
Shower & Bathtub Forum & Blog Separate or 3-Function Shower Controls Mar 9, 2009
Shower & Bathtub Forum & Blog Which is better -single shower or separate valves? Nov 13, 2008
