Can I route PEX/copper pipe through joists?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lurch, Jun 24, 2009.
  1. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    I'm partway through replacing my old forced air furnace with baseboard and I'd also like to upgrade my 1/2" main supply with 3/4". I see that a lot of the electrical cable in my 50's home is routed through the joists - is this allowed for plumbing?
    I assume not as all of the plumbing I see is hung with a gap between the top of the pipe and the joist. However some of the new lines my plumber put in for the Hot water heater are attached directly to the joist. What is the code for running plumbing lines wrt the joists? The water supply lines are copper - the baseboard are PEX.
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    This would likely fall under the building code. And it entirely depends on the type of floor joists you have.
    If you have a standard 2x? floor joist then where I am from you can run water lines through them. The issue isn't with the water lines it's with where you drill the holes. Run the water lines through the CENTER of the joist and don't drill holes bigger then you have too.
  4. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
  5. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    There's important info left off the guide, not only can the hole dia. not exceed 1/3 the width of the beam but it is restricted in location to the first 1/3 of length (either end). The middle 1/3 is off limits.
  6. hj
    boring
    It does refer to it, but that restriction is for notching, not holes through the joist. A properly drilled hole will cause minimum degradation of the joist strength. If holes weakened the structure, heavy equipment hauling trailers would not have multiple holes cut in their main frame channels.
  7. lurch
    lurch New Member
    Jun 8, 2009
    NJ
    Thanks guys - I have 2x8 joists - and the holes drilled for the NM cable looks to adhere to those guidelines.
    I was not aware you could do that.
  8. jadnashua
    The vast majority of the strength in any beam is the top and bottom cords. Look at an engineered I-joist...the middle is thin plywood.
  9. 99k
    Aug 16, 2008
    Thanks HJ, I just looked at the IPC and I stand corrected:rolleyes:
Similar Threads: route PEX/copper
Plumbing Forum, Professional & DIY Advice Does homeowner insurance usually cover water leaking fix(e.g. repipe or reroute)? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Re route vent in masterbath Sep 8, 2016
Plumbing Forum, Professional & DIY Advice Uneven toilet flange grouted to floor and cemented to pipe Jun 10, 2016
Plumbing Forum, Professional & DIY Advice (Another) Single to double vanity - best way to reroute pipes? Apr 10, 2016
Plumbing Forum, Professional & DIY Advice Drain for dishwasher. Reroute? Apr 3, 2016
