Can I roll a Wye to 45 degrees?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jeepnick, Dec 1, 2011.
  1. Jeepnick
    Jeepnick New Member
    Nov 24, 2011
    Phoenix, AZ
    Phoenix AZ here (UPC).
    My main 3" drain line is quite deep. To tie the rest of the fixtures into the horizontal main, can I roll a Y up 45 degrees to make the other lines more shallow?
    Alternatively (or in addition to) can I use a 45 to make steep depth change and then level off before entering the Wye?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Yes. Ideally the inlet of a wye will be anywhere from right on top to 45 degrees to either side of the top. Given proper pitch, it can be rolled all the way down to 90 degrees from the top, but that is usually avoided.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    short of rolling it upside down you can pretty much do anything you want with a wye. Cacher's explanation is good
  5. hj
    quote; Ideally the inlet of a wye will be anywhere from right on top to 45 degrees to either side of the top.
    There is absolutely NOTHING wrong with laying a "Y" on its side, therefore it can be rotated 180 degrees from one side to the other. HOWEVER, depending on which direction you will be going from the "Y" will determine what fittings to use because a 45 elbow will ONLY straighten it out parallel to the pipe if the "Y" is NOT on its side or perfectly vertical.
  6. Jeepnick
    Jeepnick New Member
    Nov 24, 2011
    Phoenix, AZ
    Thanks for the responses! So now that we've established that a Y can be rotated 180 degrees, what about a 45 coming off of it? If I want to roll a Y up to 45 degrees, then put a 45 off of it going off to the side (to attached to a horizontal drain which will empty into the main) can I do that or does the code say no? Or is it a bad practice? Please see attached picture for reference:
  7. Tom Sawyer
    Nov 29, 2010
    Maine
    If it makes the angle you can most certainly go right ahead
  8. Jeepnick
    Jeepnick New Member
    Nov 24, 2011
    Phoenix, AZ
    If it makes the angle... Meaning, if it makes the angle I need? Or if it makes a specific angle?
  9. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I would think you need a specific angle so they would be one and the same.
  10. hj
    The dynamics mean that if you want to go 90 degrees to the side the "Y" MUST be on its side. IF you want to go parallel to the main line, but at a higher elevation, it MUST be on its back. Any other angle between parallel and 90 degrees requires that the Y and 45 be "rotated" at specific angles to make the turn. IF the Y is on a "true" 45, then a 60 degree bend, (and they do NOT come in street pattern), will make a "perfect" 90 degree angle from the main at the higher elevation.
Similar Threads: roll degrees
Plumbing Forum, Professional & DIY Advice Rainbird controller, none of the valves are working Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Shower controller for thin wall or ? Jun 22, 2016
Plumbing Forum, Professional & DIY Advice Are Toto temperature controllers interchangeable? Sep 25, 2015
Plumbing Forum, Professional & DIY Advice Sink controlling other sinks temp Jun 12, 2014
Plumbing Forum, Professional & DIY Advice Should I roll up all my wyes Sep 9, 2012
