Can I replace an old Friedrich wall AC unit with a new Frigidaire wall unit?
Discussion in 'HVAC Heating & Cooling' started by Pickngrin, Jun 22, 2010.
  1. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    We've got an old Friedrich QuietMaster wall AC unit (I'm guessing about 18K BTU ?) that appears to have kicked the bucket today -- it's not blowing cold air anymore. I've never dealt with wall units before and would like to know if I can replace this unit with any wall unit that has dimensions the same size or smaller than the existing sleeve. Or would this involve having a new sleeve installed?
    Thanks
  2. gator37
    gator37 Retired prof. engr.
    Nov 10, 2009
    Retired prof. engr.
    Alabama
    Recommend that you check the amp draw, voltage, and recommended fuse size before you purchase. Don't know if you have a heatpump with aux heat strips or no aux. electric heat, staignt cool with no heat or straight cool with heat.
    The sleeve size would have to be your call.
    The other main thing is that the new HVAC cabinet will fit in your existing wall sleeve.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Friedrich still makes wall units, and probably has a line that is an exact match for your sleeve. Friedrich is a solid brand in air conditioners, Frigidaire is probably made by the lowest bidder in china. I have found frigidaire quality to be average at best.
  5. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Thanks. I looked further into this today, and unfortunately there is no exact fit for my old unit (SL19H30), as they have apparently reduced the size of the chassis. Apparently, there is no good solution to this problem. I was ready to spring for a new Friedrich until I found out that it is not an exact fit.
  6. hj
    The question becomes whether it is easier to make the opening larger or fill in the gap to use a smaller unit. Sometimes you may have to do both if the width and height make it necessary.
Similar Threads: replace Friedrich
HVAC Heating & Cooling Gas fireplace shutting off Dec 22, 2016
HVAC Heating & Cooling Patch or Replace Plenum Dec 9, 2016
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
HVAC Heating & Cooling Evaporator Replacement Dec 14, 2015
