Can I replace a Toto Power Gravity Valve w/a GMAX Valve?
Discussion in 'Toilet Forum discussions' started by IMALIVERU, Apr 3, 2006.
  1. IMALIVERU
    IMALIVERU New Member
    Apr 3, 2006
    I have a Toto UltraMax with Power-Gravity valve. It's about 3 years old. The flush valve has gone bad - it doesn't stop filling unless you jiggle the valve. So, I think it needs replacing.
    Question: the Power Gravity valve looks very similar to pictures I've seen of the GMAX replacement valve. Can I replace the Power Gravity valve w/the GMAX?
  2. jadnashua
    The fill valves are pretty much universal (for most brands), so yes, I think it would work. But, depending on the valve that is there, sometimes all it takes is a new seal for a buck or so.
    A completely new valve is less than $10, so it is your call. Many of the new Totos use the Korky Quietfill valve. If you replace it, make sure to adjust the water level per the instructions.
Similar Threads: replace Toto
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Today at 3:44 PM
Toilet Forum discussions Norris toilet replacement with a Toto? Jan 31, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Toto Flapper replacement Mar 9, 2016
Toilet Forum discussions Toto Drake - original flapper replace or fix - part # confusion Jan 27, 2016
