Can I install an expansion tank on abandoned water softener loop?
Discussion in 'Water Heater Forum, Tanks' started by Austin83, Mar 30, 2013.
  1. Austin83
    Austin83 New Member
    15
    Texas
    After some consideration, I have decided to move my expansion tank from the attic to our insulated garage. There is an old water softener loop in the garage about 12 feet from the hot water heater (water softener was removed years ago by previous owner and loop was left). I have heard that an expansion tank can be added anywhere on the cold side, but I don't know anything about softener loops. There is a cutoff valve on the loop and when shut off it cuts the water throughout the house. Any reason why this wouldn't be a good place to install it? Thanks.
  2. jadnashua
    21,948
    To pass code, the expansion tank should not have any valve between it and the WH. This is to ensure that it always has an open path to the WH to absorb the expansion. From a practical matter, as long as the valve(s) remain open, it will work just fine.
  3. Austin83
    Austin83 New Member
    15
    Texas
    Thanks for the help!
Similar Threads: install expansion
Water Heater Forum, Tanks Installed too small of an expansion tank Mar 31, 2013
Water Heater Forum, Tanks Recommendations for proper way to install expansion tank with new water heater Jul 27, 2011
Water Heater Forum, Tanks Opinion on expansion tank installation. Picture included. May 23, 2011
Water Heater Forum, Tanks New Expansion tank installation....necessary ? May 25, 2009
Water Heater Forum, Tanks Gas water tank install Aug 1, 2014
