OK, I guess there aren't any other solutions for a wall discharge flange that's too far in and not 100% straight. Too far in for the neoprene seal to bond. In order to bring it out a bit more I was thinking about buying a regular 3" ABS flange piece and cutting off the rim, so that I end up with a ring. This ring I would glue onto the exisiting flange face with ABS cement. If not thick enough I could probably glue two of those on there. Would be really nice to get another 1/4" or so. The usual method of silicone and screwing in an extender doesn't work here because it's in a wall, nothing to grab into.
Is it ok to glue an ABS ring flat-face onto an ABS flange rim?
Also, I've got a full can of ABS cement that's a few years old. Would it still be good or does that stuff rot in the can?
Regards, Joerg.
Regards, Joerg.
