Can I connect PEX directly to water meter in basement? (NJ)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gil716, Sep 13, 2011.
  1. gil716
    gil716 New Member
    Sep 13, 2011
    Northern NJ
    Hello, after learning a lot from this forum, I've decided to redo the main trunk in my house with PEX. I heard from a friend's plumber that the New Jersey code does not allow you to connect PEX directly to the water meter. Has anyone ever heard this before? I understand why a water heater needs to have copper, but why the water meter? I assume that I would have to extend the ground from the incoming pipe all the way to my cluster of copper pipes?
    Thanks.
  2. hj
    The only time I have heard of this requirement was when the water meter was outside the house, then they require about 3' of copper from the meter before changing materials. The usual reason being that when the plastic line broke, you did not have to disturb the meter to fix it.
  4. gil716
    gil716 New Member
    Sep 13, 2011
    Northern NJ
    Thanks for the quick reply. The meter is inside the house so perhaps he just forgot the part about being outdoors.
  5. hj
    IT could also be a local thing to make your life more difficult, and/or make more work for plumbers.
Similar Threads: connect directly
Plumbing Forum, Professional & DIY Advice Can Hose Bib (Brass Male) Be Connected Directly to Copper (Female) Not Fitting Smoothly Oct 14, 2014
Plumbing Forum, Professional & DIY Advice Connect lav drain directly into toilet Sep 18, 2013
Plumbing Forum, Professional & DIY Advice Connect toilet directly over main drain. 3" clearance under subfloor to top of drain. Oct 31, 2012
Plumbing Forum, Professional & DIY Advice Copper Connectors directly to Water Heater Question Jan 29, 2008
Plumbing Forum, Professional & DIY Advice Proper fitting to connect to main...Fernco? Feb 16, 2015
