Can I build this Console
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nmchugh6, Oct 21, 2008.
  1. nmchugh6
    nmchugh6 New Member
    Oct 15, 2008
    Yikes...the console sells for about $700. Anyone have ideas how I can make this? Would plumbing supply store have materials? What type of business would likely cut the measurements? Is some other business a likely source for material and sizing?
    http://stthomascreations.com/Products/productDetail.aspx?sku=5010.680&familyID=70[/URL]
  2. jimbo
    jimbo Plumber
    First, you probably can't buy that sink by iteself. As far as trying to cobble together a frame like that to fit some other sink, it would look like it was made by third grader at the lego factory.
  4. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    I can post what I did instead. I knew I wanted a console sink and searched high and low for one that looked nice without breaking the bank.
    I settled on one from american standard called retrospect 7812.002 . I think I picked it up online for just over $400. I found plenty of others in the $400-3000 range.
    I'm very happy.
      File size:
      16.6 KB
      179
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    that look nice
    the american standard unit looks pretty nice,
    but for some weird , perverse reason I really want to see
    what this fellow rigs up on his own.......
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Amazing how all that was old is suddenly new again.
    Next they will bring back the enamled steel kitchen.
  7. hj
    retro
    And 23" deep Nappanee steel cabinets.
  8. nmchugh6
    nmchugh6 New Member
    Oct 15, 2008
    The sink is available on its own..the console is expensive and I'm a somewhat capable (yet Scottish/cheap) girl who's looking at the console asking,,, can't I do it on my own? I am in no way a professional but I look at the console, see railings and 2 fittings on the legs that enable connection of the bar between the two legs and then bars running back to the wall.
    Am I nuts to think that I can get the railings and fittings from a plumbing supply or another type of business and have either the contractor or myself put it together?
    The Pyramids were built thousands of years ago...some responses are giving me the impression this is near impossible...is it really?
  9. jadnashua
    You could make it out of wood. Making it out of metal would require skills and tools you probably don't have. Steel would have to be welded, the joints machined smooth, then the thing chromed (unless you wanted it painted). None of those operations are all that hard if you have the skill and the tools, but the time it would take you would likely still make it cheaper to buy. Actually, doing it in wood requires skills, too if you want it to look good.
Similar Threads: build Console
Plumbing Forum, Professional & DIY Advice Where can backwater/backflow valves be used in a building? Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Is rebuilding a Pressure Regulator worth it? Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Green Buildup on Copper Pipes: Big issue or not? Aug 9, 2016
Plumbing Forum, Professional & DIY Advice Grey water system on a new house build Aug 7, 2016
Plumbing Forum, Professional & DIY Advice Builder had p-trap installed below kitchen cabinets Jun 11, 2016
