Can a PRV be installed in line between street and house?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by larrymcg, Oct 18, 2010.
  1. larrymcg
    larrymcg Member
    Dec 28, 2009
    Silicon Valley
    The pressure in the house is 80psi and a PRV has been recommended. However, I'd like to reduce the pressure to the house and to the yard watering system. The line from the street comes up next to the house and splits. One line goes into the garage and the other goes into the yard watering system. Both lines have shut-off valves so I can independently turn the house and yard water on and off.
    Can a PRV be installed in the line from the street, under ground, before the line comes up out of the ground?
    --Larry
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I see no reason why not, but I'd devise a way to have access to it and not just bury it. Given your location, I doubt if freezing is an issue. Do you know you will also need to install a thermal expansion tank before the supply line reaches the water heater?
  4. larrymcg
    larrymcg Member
    Dec 28, 2009
    Silicon Valley
    Thermal expansion tank? I guess I should find out what that is and why I would need one.
    Freezing? Sometimes water above ground will get some surface ice on it but it never seems to freeze all the way through. And any distance below ground doesn't freeze.
    --Larry
  5. Hardt
    Hardt Member
    Nov 18, 2005
    Hawaii
    FWIW, I wouldn't bury in underground...it will corrode faster and possibly shorten its life and you wouldn't have easy access to it to adjust the pressure.
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    When a water heater heat water, the water expands and has to go somewhere. Before the PRV was installed, this expansion is easily absorbed by the city water main, so no problem. However, a PRV has a check valve that prevents this from occurring so the expansion has to find another place. The pressure rises in the water heater tank until it reaches the limit of the temperature/pressure safety valve on the tank and trips the valve open to release the excess pressure. This prevents the tank from exploding like a bomb. (literally) The thermal expansion tank provides a temporary space for this expansion to go. It is installed in the cold water supply to the water heater between the PRV and heater. It is charged with air to match the PRV setting. I understand that some newer PRVs have a bypass that allows for expansion, so you might check with your PRV for that feature.
  7. Hardt
    Hardt Member
    Nov 18, 2005
    Hawaii
    Oh, I forgot to mention that I have a faucet before the PRV and its psi is 100+ and its great for spraying off moss, dirt, etc of the sidewalk, rock walls, etc. So I would think twice about reducing your 80 psi yard watering service!
  8. Terry
    Aug 17, 2004
    Yes you can install a PRV below ground. It may be a good idea to box it though in order to have access to it later.
    Sometimes I replace old ones that have been buried. Kind of hard to find them that way.
  9. jadnashua
    They make boxes for this sort of thing. You might use a covered one designed for sprinkler controls.
Similar Threads: installed line
Plumbing Forum, Professional & DIY Advice Installed new kitchen sink and water lines don't reach now, need to get an extension Sep 29, 2012
Plumbing Forum, Professional & DIY Advice Is this a check valve installed on my WH return line??? Apr 26, 2010
Plumbing Forum, Professional & DIY Advice how do I purge gas line? I installed new gas range. Sep 12, 2006
Plumbing Forum, Professional & DIY Advice Corian tub/shower surround installed over Redgard Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Towel Rail Radiator Installed Sideways Jan 21, 2017
