Can a 32" tub go where a 30" was?
Discussion in 'Shower & Bathtub Forum & Blog' started by AK-Maxx, Dec 1, 2009.
  1. AK-Maxx
    AK-Maxx New Member
    Dec 1, 2009
    Anchorage AK
    I'm replacing my old tub, but the new one I like is 32", the old one is 30". I'm on a second floor, and have not yet removed the old tub. What needs to be done to install a 32"?
  2. Terry
    Aug 17, 2004
    They are the same length.
    Plumbing code requires 15" from the center of a toilet, to the edge of a tub.
    If you install a 32" tub, it will be 2" closer.
  4. AK-Maxx
    AK-Maxx New Member
    Dec 1, 2009
    Anchorage AK
    Will I have problems with the drain lining up? I'll have to drill ne holes in the surrond, so that doesn't matter too much, I'm mostly worried about the drain. I have well over 15" to the tub frm the toilet.
  5. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Unless you are replacing the tub with the exact model of the old one, you will have to re-plumb the drain.
  6. jadnashua
    In other words, it would be a fluke if the drain lined up!
    Now, whether you're lucky or not, it could be easy. If there's a joist in the way, it could get ugly. You won't know until you look.
  7. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Installing a tub can be a real pain the ass I'm not gonna lie. Sometimes you can't get at the drainage from below or the side so you have to measure up carefully and have the drain in place so when you set the new tub down it hits the drain bang on.
    Each bath tub is a unique adventure :D You never know what you're up against until you rip the old tub out.
  8. hj
    tub
    You have to relocate the drain, and also the faucet to make it look proper and centered on the drain. I assume the surround is a separate unit, otherwise you will not get it into the room, nor into position.
  9. AK-Maxx
    AK-Maxx New Member
    Dec 1, 2009
    Anchorage AK
    The tub and surround will both be separate. I'll just have to look, then I'll start asking more questions. Thanks.
Similar Threads: where
Shower & Bathtub Forum & Blog New acrylic airtub installation, where to put ledger? Nov 25, 2016
Shower & Bathtub Forum & Blog No water in shower and tub but water everywhere else in the house Sep 23, 2016
Shower & Bathtub Forum & Blog New shower valve...Where to buy? Nov 4, 2015
Shower & Bathtub Forum & Blog Where to cut tile when it's too cold outside: Tile Setter tips Dec 4, 2014
Shower & Bathtub Forum & Blog Tile to Hardwood Transition: Where to join the two Nov 17, 2014
