Calcium in water lines
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ShellyPace@hotmail.com, Feb 8, 2009.
  1. ShellyPace@hotmail.com
    ShellyPace@hotmail.com New Member
    Apr 17, 2008
    I have a 14 year-old house in Austin Texas and I think I have some serious calcium buildup in my lines. I'm always having to clean out the aerators throughout the house and when I fill my bathtub up, there are always little chunks of white pieces that crumble when I crush them up.
    Is there a way to clean the calcium out of the pipes throughout the house? If I install a water softener would that work or would that just keep the calcium from building up anymore?
    Sincerely,
    Single Female homeowner :rolleyes:
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. ShellyPace@hotmail.com
    Apr 17, 2008
    Thank you so much for your reply - it was very helpful! I did the vinegar test and am excited to report that the pieces didn't dissolve so I'm assuming that it is my dip tube. Do you have a good website with an explanation on how to replace it? Is it very hard to do?
    Shelly :)
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Well Shelly I'm afraid that it isn't really good news.
    The Dip Tube is located under the cold inlet to the water heater. To replace it the cold line would have to be cut then unscrewed from the water heater to allow any remaining parts of the dip tube to be removed and the new one installed. The water heater would have to be flushed to get any of the remaining pieces out of the heater and even then there probably will be some left.
    Any water heater with a bad diptube is at least 10 years old and is near the end of it's expected service life. In the case of your 14 year old home I would assume that the water heater is 14 years old. You probably would be better off replacing the water heater. You may be able to get away with replacing just the diptube depending on the condition of the water heater, Then again the very act of trying to unscrew the nipple on the inlet could start a leak that will never stop. Or, the water heater may spring a totally unrelated tank leak one day after fixing it.
    I would recommend replacement of the water heater. If it is a gas water heater you want it replaced with a Bradford-White or, Rheem. You do not want a water heater from Lowes under any circumstances. They sell water heaters made by American Water Heaters which have some bad problems.
  6. ShellyPace@hotmail.com
    Apr 17, 2008
    Well poo!!! I've known for a while that the water heater was close to its death - been making some popping noises every now and then for the past two years. Gotta love how everything comes around tax time! :eek:
    Thanks for the suggestion on the brands - I'll definitely avoid Lowe's.
    Thanks again!
  7. Redwood
    Dec 15, 2007
    Service Plumber
  8. ShellyPace@hotmail.com
    Apr 17, 2008
    Wow!!! So glad to know that!:eek:
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Another new water heater owner saved from the plague of American Water Heaters...:cool:
  10. Cass
    Cass Plumber
    Nov 12, 2005
    If you post the Brand, Mod. & Ser.# of your water heater we can tell you how old it is...
Similar Threads: Calcium water
Plumbing Forum, Professional & DIY Advice Calcium "gravel" in water lines Mar 24, 2008
Plumbing Forum, Professional & DIY Advice What Calcium Buildup Cleaner is Safe to Use on Toto Nano-Finish Toilets? Oct 25, 2014
Plumbing Forum, Professional & DIY Advice How do I Clean Calcium/Lime Deposits in Main Line Jun 18, 2014
Plumbing Forum, Professional & DIY Advice Replacing about 4ft of exposed waste line, calcium deposits in the pipes Jan 9, 2014
Plumbing Forum, Professional & DIY Advice Calcium and Lime Clog In Cast Iron Pipe Dec 21, 2006
