Cable Drain Replacement
Discussion in 'Shower & Bathtub Forum & Blog' started by robhughes1, Aug 3, 2008.
  1. robhughes1
    robhughes1 New Member
    Aug 3, 2008
    Contractor who remodeled our bathroom put in a very cheap PVC cable tub drain, very hard to turn, handle is plastic and comes off in your hand when you turn it, etc. Pretty sure they just bought the cheapest thing available at HD.
    Wondering if anyone might have view on how big a job it is to replace with something better?
    Thanks in advance.
    Rob
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Is there access from under the tub via a basement, crawlspace, ceiling on the floor below? Is there access from a wall in a room or closet behind the tub?
    I'm not a fan of cable drains.
    IMHO there is no better drain than this Gerber waste and overflow.
    [​IMG]
  4. hj
    drain
    Wear is the problem with any cable drain. The degree of difficulty depends on what kind of access you have to it.
  5. robhughes1
    Aug 3, 2008
    drain
    surprised if its wear, contractor just put in new one < 6 months ago. Think its just a piece o'crap...
    Access is limited, probably involves removing recently done tile and backer on shower wall to access the tub drain. Shame since we just had whole bath redone...
  6. Redwood
    Dec 15, 2007
    Service Plumber
    That doesn't sound like the way I would gain access.
  7. hj
    cable
    The wear in a cable drain is often the fulcrum that opens and closes the drain plug.
Similar Threads: Cable Drain
Shower & Bathtub Forum & Blog How to use a "LoudMouth - Screamer" while installing floor heat: Cable or Mat Dec 1, 2013
Shower & Bathtub Forum & Blog Using Cable Electric Heat as a primary heat source in your bathroom (Heat Loss Calc) Aug 25, 2012
Shower & Bathtub Forum & Blog Reliability of cable-driven bath waste? Jul 2, 2012
Shower & Bathtub Forum & Blog Waste and Overflow -- cable drive or push pull Apr 4, 2008
Shower & Bathtub Forum & Blog Bath faucet - plastic housing leaking, replacable? Oct 16, 2006
