Cable connectors necessary?
Discussion in 'Electrical Forum discussion & Blog' started by Bassman, Dec 13, 2007.
  1. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    I'm installing under cabinet lights in the kitchen. Simple flat (approx. 1 1/8") flourescents. One of the fixtures has to be fed from one down the line via a loop of 14/2 in the wall. The little connectors (mini Romex clamps) provided for the fixture can't accomodate two 14/2 cables, so what is commonly done? Since the fixture will be flush with the backsplash, my inclination is to leave it off. Suggestions? Thanks.
    Neil
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Get a second connector. They're a bit hard to find, but they're out there...
    The fixture ought to have more than one knockout - if not, drill a 2nd hole.
    Use a proper step-bit, to get a smooth hole.
  5. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    Thanks guys. It never occurred to me to just make the hole bigger and put a proper size connector in. I only needed one right now so I just filed the hole bigger and inserted a standard Romex clamp. When the backsplash gets tiled, it looks like those plastic snap-in clamps are the ticket.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Is the junction of the fixture large enough to accept all these wires?
  7. Bassman
    Bassman DIY Member
    Aug 25, 2006
    musician
    Ventura, CA
    By "junction" do you mean the interior space of the fixture? The fixtures I bought all have extra leads capped off inside for extending to another fixture. Everything seems to fit.
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    He has two cables entering the fixture... Without actually reading the specs on the fixture, I'm gonna say he's probably fine...
Similar Threads: Cable connectors
Electrical Forum discussion & Blog Using "MC Lite" (aluminum jacket) cable connectors Oct 13, 2016
Electrical Forum discussion & Blog Switching between AC and MC cable? Oct 13, 2016
Electrical Forum discussion & Blog Underground cable Oct 2, 2016
Electrical Forum discussion & Blog Surface mounted armored cable, or EMT? Sep 21, 2016
Electrical Forum discussion & Blog Limitations on NM cable in tall structures? Aug 18, 2016
