roachslayer
I'm super confused. I just bought a CST744SG (Drake 1, 1.6gal CEFIONTECT model). But now looking at the box, I see this: C744E#01.
huh? What happened to the "G" for CEFIONTECT?
Quick Gloss History:
As I understand it, "CEFIONTECT" is apparently is the USA name for CeFiONtect. And, apparently, as of some recent point in time, Toto has pretty much dropped CEFIONTECT and just using "CeFiONtect" for ALL markets.
OK, with that in mind, I then found the Toto Spec sheets from BOTH eras (when CEFIONTECT was the name, and the newer one with CeFiONtect as the name).
Older spec sheet for CST744SG here:
https://terrylove.com/pdf/cst744eg_spec.pdf
This spec sheet mentions "C744E" for the bowl (in the "CEFIONTECT era").
New/Current CST744SG spec sheet on Toto site here:
https://terrylove.com/pdf/cst744eg-specs.pdf
This spec sheet mentions "C744E(G)" for the bowl (in the "CeFiONtect" era).
If you're seeing why I am seeing, yes, it's really stupid that they use (G) in the CeFiONtect spec sheet, but no (G) in the CEFIONTECT spec sheet. But what is REALLY DUMB about these spec sheets is that they try and accommodate BOTH the CST744SG AND CST744S (no CEFIONTECT), it specifically mentions the difference in model numbers (CST744S vs CST744SG) and indicates which has CEFIONTECT, and yet only ONE bowl is listed as a component of that model (grrr)!!
Question:
So what is the deal? Do I have the wrong bowl? Is C744E without CEFIONTECT?
Question:
