bypass shower doors
Discussion in 'Shower & Bathtub Forum & Blog' started by JEP, Mar 3, 2006.
  1. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
    I'm not sure this is the right place in the forum for this but here goes. I'm installing bypass shower doors on a standard 5' tub. The upper and lower tracks need to be cut. Any tricks, or ideas on how to get real nice straight cuts on these? Is there something better to use that a hacksaw that will give me a more square cut? Would some kind of blade in a chop saw do it?
  2. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    i use a regular blade in a chop saw. just cut real slow and wear glasses. then a file on the rough edge. perfect cut!
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A small miter box and hacksaw will work OK, but work slowly. Use a file to remove any rough or sharp edges.
  5. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
    Thanks for the responses guys. I'm going to give the chop saw a shot. I'll do a test cut on the very end to see how it goes.
    Sulconst2 - Do you face the top (solid) side up or the track side up when you cut - or doesn't it make a difference?
  6. sulconst2
    Jul 11, 2005
    remodeler
    old bridge nj
    solid side up would probably be better just go slow. don't forget the glasses! :eek:
  7. jadnashua
    I've cut two of those with a 60-tooth blade on a radial arm saw. The carbide can handle the aluminum fine, but go slow so you don't bog down or overheat anything.
  8. sulconst2
    Jul 11, 2005
    remodeler
    old bridge nj
    definitely the way to go. its finish work. really sticks out if its a bad cut. been using a chop saw for years on these. just turn your head cause it spits metal all over. but the cut is sweet!
  9. JEP
    JEP New Member
    Nov 11, 2005
    Ringwood, NJ
    Cut like butter. Thanks guys.
Similar Threads: bypass shower
Shower & Bathtub Forum & Blog Custom Glass Bypass Shower Door Kits Jul 18, 2014
Shower & Bathtub Forum & Blog Basco bypass shower door drip molding sought Aug 14, 2013
Shower & Bathtub Forum & Blog Bypass Shower Door- Bottom Track Not Sitting Flush Aug 6, 2013
Shower & Bathtub Forum & Blog Bypass Shower doors May 6, 2012
Shower & Bathtub Forum & Blog Bypass Tub/Shower Door w/radius corners? Aug 30, 2008
