Tuccisal
- Messages
- 1
- Reaction score
- 0
- Points
- 0
Hello - I have a Wellmate water tank (with a bladder) that seems to not be working correctly. I was advised to check the pressure of the tank via the nozzle at the top of the tank. I was also told that if you press on that nozzle and both water and air comes out, then the bladder is busted.
Low and behold, there is indeed a lot of water coming out of the nozzle when I checked the air pressure. I've done some research of the internet and have found conflicting information about a solution which I'm hoping someone can help clarify.
1) Ultimately the tank will need to be replaced or at the very least the bladder if this is an option. Most people recommend replacing the tank.
2) To immediately rectify the sitaution without incurring the expense of a new tank, someone mentioned that a tank with a broken bladder is the equivalent of the 'old' tanks that didn't contain a bladder. Therefore, my broken bladder tank is the equivalent of a 'waterlogged' bladder-less tank. They recommended I drain the tank as if it were an 'old' tank and then just pump the air pressure back in. Is this true??? and is this a viable option for a short term fix until I can get the tank replaced??
Any light you can shed on these two points would be greatly appreciated.
Thanks
Sal
Thanks
Sal
