Hi Guys - I am new here and looking for advice.
The PRV was blowing off every know and again the past week for the first time. After reading up I determined the expansion tank was bad. There was water out the bottom when I checked pressure. I thought the pressure was to high so I lowered to 12PSI and it became waterlogged. Lowering of the tank seemed to have brought the boiler PSI back to 18-20psi max. The pressure would drop and then rise when the boiler fired.
I changed the expansion tank and purged my system and zones. The pressure still fluctuates between 12-20 when the heating system is running and calling for heat to the zones. I verified the auto fill was not the issues by shutting it off and verifying no pressure change while idle, in addition auto fill off the pressure still fluctuates when running but no more than psi.
At this point I thought I was fine. However when domestic water is called for the boiler fires when water temp is 160ish and shuts down around 180-185ish. When running the domestic the boiler seems to struggle to get the water back up to temp and the pressure builds to 38psi and water runs by the PRV due to it being 30psi, but doesn't blow off and dump much water.
My thoughts at this point is the tankless coil for the domestic water has a pinhole leak.
Thoughts?
Thoughts?
