Bulging hot water tank
Discussion in 'Water Heater Forum, Tanks' started by MR_B, Mar 29, 2009.
  1. MR_B
    MR_B New Member
    Mar 28, 2009
    DOD
    Pittsburgh PA
    Good Afternoon,
    First of all, please excuse my ignorance. I recently noticed that my hot water tank was bulging out of one side, after some moderate research I discovered that it was due to not releasing the pressure from the Pressure release valve.
    I was wondering if it is pertinent for me to change out my hot water tank ASAP? What kind of damage was done by not releasing this built up pressure?
  2. hj
    tank
    Replace it IMMEDIATELY. The problem is not so much that it is bulging, but rather WHY it bulged. It implies that the tank was on the verge of a catastrophic failure, which would have destroyed your house and ANYONE in it. After the new tank is installed verify that the safety valve is ABLE to operate by lifting its lever and making sure the water is escaping somewhere around the house. I had one house where the safety valve opened, but the drain line was plugged somewhere in the walls so the water could not flow.
    http://www.waterheaterblast.com/
  4. MR_B
    MR_B New Member
    Mar 28, 2009
    DOD
    Pittsburgh PA
    Wow, Thank you. I rent so I hope that it's not a problem to have it replaced quickly.
  5. hj
    Tank
    If it is, call your city building department, because this could be a serious safety issue, not just for you, but for the neighbors. A heater like that blew up in Phoenix recently. The water heater landed a block away. The house had to be leveled, AND the insurance company refused to pay the claim because the heater had not been serviced properly.
  6. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I had a home owner call me and e-mailed me pictures of her water heater. She said she heard a loud pop noise from the basement and found that her heater was bulging. I told her to leave her home immediately, and I will be there ASAP. When I got there I I turned the gas off to her home went down to the basement and turned on the laundry tub faucet and steam came out of it. Her thermostat on the water heater had failed and the P&T valve was frozen. It was a ticking time bomb.
    Here are the pictures
    [​IMG]
    [​IMG]
  7. MR_B
    MR_B New Member
    Mar 28, 2009
    DOD
    Pittsburgh PA
    That's exactly what it looks like. I'll shut the gas off and call my landlord today.
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Do not let you landlord stall you about the replacement. He legally is obligate to replace that tank immediately. If he gives you any run around trying to stall the replacement, go to the city immediately. Do not use the heater at all.:eek:
  9. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Should the heater be drained?
    Water to the heater turned off?
    Hot water valve on a sink be opened to relieve pressure?
  10. SewerRatz
    Nov 20, 2008
    Chicago, IL
    After turning off the gas or electricity to the heater, I would go to the furtherest faucet and turn on the hot tap..
    Terry thanks for adding the link of the water heater blast to my post. If you have not seen the video of the water heater blast that Mr Randall Hilton has made please go check it out. http://www.waterheaterblast.com/
  11. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    thats a nice one
    looks like a 75 gallon brad white power vent
    age about 13 years or so....
    that would be a good one to see crack open like
    an aresol can... would do a lot of damage to
    everything around it..
    now , I just have to post my personal best..
    this one took out the water softener next to it
    [​IMG]
  12. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would consider this to be a good course of action.
    You could also defuse the situation by turning off the gas at the meter and opening an sillcock unless there are check valves isolating the water heater.
  13. hj
    Heaer
    The important thing is to stop the energy supply to the water heater. Either turn off its gas supply, or turn off the electricity to it. If it cannot heat, then it cannot explode.
  14. MR_B
    MR_B New Member
    Mar 28, 2009
    DOD
    Pittsburgh PA
    Tank Fixed
    I just wanted to thank everyone on here that replied quickly to my post about the hot water tank. Thank you very much. The tank is fixed now :D, It was replaced yesterday by 6pm, took a measly 3 hours to install with a friend, could have been quicker but I was having issues with the flux taking on the copper, a couple more quick brushings with the paper and I was back in business. Without the help of you fine people who knows how long it would have taken me to take action.
    Thanks again all and I look forward to posting on here again in the future.
  15. ChuckS
    ChuckS New Member
    Mar 17, 2009
    Aurora, CO
    That's nothing a little duct tape can't fix... Duct tape can fix anything...
  16. Redwood
    Dec 15, 2007
    Service Plumber
    I believe you are correct sir however in this application I would consider it wise to have the first layer of tape to be the fiberglass reinforced packing tape for extra strength.:cool:
  17. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Well on the positive side your 50g tank has expanded to a 55g tank at no charge :)
  18. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    And almost had a skylight... :rolleyes:
  19. drick
    drick In the Trades
    May 16, 2008
    Do you have a link to an article or anything indicating that the insurance co would not pay? Do you know what insurance co it was? I'm interested because my wife works for a major insurer and indicated that would in fact be covered under most of their homeowner policies.
Similar Threads: Bulging water
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Long wait for hot water Feb 7, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
