DavidTu
What needs to be done to run ABS under newly poured concrete slab perimeter in terms of protection for the pipe? What about ABS penetrations through the slab? Do these need to be wrapped with a sleeve and if so what sort is it? Also, is it the regular ABS or something special?
Also, for going from building drain to side sewer the original drain was buried cast iron under the slab. What is recommended for replacement? Is ABS preferred over cast iron in terms of longevity?
Thanks.
Thanks.
