Building a P-trap
Discussion in 'Shower & Bathtub Forum & Blog' started by SH140, May 28, 2013.
  1. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
    Getting ready to install plumbing for new tub install, and wanted to know ahead of time if there are any limitations when installing the p-trap. I know that the standard trap is a fairly tight radius. If need be, could a trap be made with two 90o elbows with a straight connecting pipe at the bottom ? if so how long can connecting pipe be so that the trap still functions correctly? (1", 3", 12" ???) If not, is it because the trap operates more efficiently with a tight turn in a shorter length?
    Also, where there will be no access to the plumbing after the tub goes in, is it better to use only glued joints in the ABS plumbing?
    Thanks
  2. Terry
    Aug 17, 2004
    A longer run would be more inclined to gunk up.
    Glue joints are always better then slip joint where there is no access. In fact it's now a requirement.
    I've made traps using street medium 90 bends.
  4. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
    I kinda thought that was the reason. Thanks
    I was wondering...does plastic pipe cement ever go bad? If it's still in a liquid state, is it still good to use. Mine is a few years old, but still looks OK.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    If the can has ever been opened, it is questionable. The cement should be very "liquidy". Any signs of gel-like texure is a no-go.
  6. SH140
    SH140 New Member
    Jan 31, 2013
    Vallejo, Ca.
    Thanks for the tip. Because the plumbing won't be accessible afterwards, I bought a new can. Better safe than sorry.
Similar Threads: Building P-trap
Shower & Bathtub Forum & Blog Need a little advice, building shower pan Mar 3, 2016
Shower & Bathtub Forum & Blog Rebuilding Price Phister Avante Single Shower Hot/Cold Valve Nov 26, 2015
Shower & Bathtub Forum & Blog Building a basement shower from scratch Oct 24, 2014
Shower & Bathtub Forum & Blog Building wet shower wall May 13, 2014
Shower & Bathtub Forum & Blog Installing a Linear Drain: Residential Building Magazine Kitchen & Bath Issue 2014 Apr 8, 2014
