Building a better tile shampoo shower niche - a how to guide
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Sep 29, 2012.
  1. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Building a better shampoo niche takes time and skill. The efforts will net you a less cluttered looking shower with more shower storage. There are so many ways to do this and so many ways to screw it up badly. There is of course a few simple rules I follow and things I like to do to make a niche look and function better.
    The niche should look nice, function well and drain super well. Most ready made niches are made from cheap foam and have no slope to the bottom. This is a mistake and easy to correct if you have all ready purchased one.
    The custom niche below is for my buddy's daughter. Designed low for play time. The light is a must for elevating the play time enjoyment and the night light options in this bathroom.
    [​IMG]
    My buddies daughter's tub shower renovation. The LED's part of a lighting plan for this space.
    JW - "When it's perfect. It's Good Enough."
    www.No-Curb.com - my blog site on Barrier Free, No Curb, No Dam and Hobless Showers
    (604) 506-6792 jfrwhipple@gmail.com
  2. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Building a shower niche (How to Guide) - Setting the back tile tight
    You need to max out space for most shower niches.
    Typically the largest a shower niche can be is the width of the wall framing plus 1/4". With a 2"x4" wall this equals 3 3/4". With a 2"x6" wall this equals 5 3/4".
    [​IMG]
    The lower niche is more for play time. The long space perfect for bath time. The larger taller niche to the right will be for shampoo and conditioner bottles.
  4. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Centering the tile niche on the plumbing fixtures
    Layout of the niche is critical to the over all design. This is why we design the tile layout before we even do the framing upgrades.
    Tile layout and lighting layout should be done first - at the very beginning.
    [​IMG]
    You can see I used up some scraps on the back side of the shower niches. I do not currently use Kerdi or Kerdi DS. Neither product is on my recommended supplier list for multiple reasons I will not get in too here
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Building a shower tile niche - layout 101
    More info on building a better shower niche here.
    http://no-curb.blogspot.ca/2014/05/building-better-tile-niche-shampoo-shower.html
    [​IMG]
    A better shampoo niche starts with better framing and better backer boards.
    This Wonderboard Lite from Custom Building Products is the best backer board on the market today - my opinion.
  6. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Building a custom shower niche with Denshield
    [​IMG]
    Another photo of a custom niche - but this one is for the toilet paper. Saves space and works as a perfect night light.
  7. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Building a shower niche in a steam shower or steam room
    No grout as yet. This low niche is perfect for shaving your legs. Perfect for shower sex. And perfect for setting the mood in the shower. Not grouted as yet. One of my favourite shower builds of all time this one....
    [​IMG]
  8. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Building a niche that meets the long wall
    Full topical waterproofing. You can see the Noble Flex drain flashing in this photo.
    [​IMG]
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Building a Marble Tile Shower Niche - Shower Cubby
    Small niche - another one designed with the long wall running into the niche. On this project the bathroom was huge. We build out the back wall with 2"x6" joists to prepare a niche for the tub filler.
    [​IMG]
    [​IMG]
    Action shot of the top tile being set.
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Building a shower niche or cubby - Prepare a grout sample board
    Another low niche for shaving - or not ;)
    [​IMG]
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Tips for building a shampoo shower niche larger
    To remove this section of wall stud I first drill a series of small holes in three directions through the stud to be removed.
    This is a non - load bearing wall and the drilling process makes cutting out the stud easier.
    [​IMG]
  12. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Cutting out a wall stud - non load bearing wall
    This is my Japanese pull saw in action
    [​IMG]
  13. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    What is the best size for a custom shower niche?
    [​IMG]
    Many times one full tile looks best.
  14. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    [​IMG]
    Steam Shower: NobleSeal TS Shower Niche
  15. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Designing playtime into a shower niches' location
    [​IMG]
  16. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Using masking tape while building triple shower niches
    [​IMG]
  17. Keithett
    Keithett New Member
    Dec 13, 2012
    Tigard, Oregon
    John,
    I've been reading up on how you create a shower niche and if I understand this correctly, you create an oversize waterproof niche opening so you have the ability to adjust the tile as necessary to match the surrounding tile. I'm going to be tiling a new shower next year and also want my tiled niche to match up exactly with the surrounding tile and like this approach. What I wanted to know is the best way to fill in the approximately 1" (plus or minus) gap behind the tile. Instead of filling this gap with thin set, would it be better to grout in a shim between the niche and the tile? If water behind the tile is a concern, I could make this shim out of a non-porous material.
  18. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    John that small shower room w/ the toilet in it, does water make it almost to the door or what?
  19. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Grouting Outside Corners
    [​IMG]
  20. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Hydro Ban Steam Shower Niche Build.
    Vertical cut out in framing.
    [​IMG]
  21. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    [​IMG]
    Edges and corners still need banding.
Similar Threads: Building better
Shower & Bathtub Forum & Blog Building a basement shower from scratch Oct 24, 2014
Shower & Bathtub Forum & Blog Building wet shower wall May 13, 2014
Shower & Bathtub Forum & Blog Installing a Linear Drain: Residential Building Magazine Kitchen & Bath Issue 2014 Apr 8, 2014
Shower & Bathtub Forum & Blog Money Saving Shower Building Tips: How to save money when building your next shower Jan 14, 2014
Shower & Bathtub Forum & Blog Building-up an existing shower curb Nov 27, 2013
