buderus wall-hung won't fire
Discussion in 'HVAC Heating & Cooling' started by shenelec, Nov 24, 2007.
  1. shenelec
    shenelec New Member
    Nov 24, 2007
    I have a Buderus GB-142, installed about a year and a half ago. Thanksgiving morning, it was reading error code 6A, which means it tried to fire 3 times and then gave up. Turning the power off and back on reset the system and solved the problem for the time being.
    Today, it's off again. Now, the boiler makes this gurgling noise, as if there's air in the system, while it tries to fire. After 3 tries, it kicks out again.
    So, while I'm waiting for the plumber who installed the system to answer his pager, I wonder if you can help a poor electrician diagnose this problem.
    Pressure reads 20psi
    I'm thinking I should purge it somehow, but do I need to drain the whole system? It's radiant plus dhw.
    Thanks for any advice.
  2. shenelec
    shenelec New Member
    Nov 24, 2007
    no heat; help!
    House temperature is dropping through the 50's; any help appreciated.
  4. shenelec
    shenelec New Member
    Nov 24, 2007
    problem solved; condensate vent was blocked
  5. BigLou
    BigLou New Member
    Nov 7, 2007
    What was blocked the condensate line or the vent it self ? I would have mentioned that it won't fire if the vent was blocked but I have ben busy in my basement installing a new GB142. how do you like it ?
    Lou
Similar Threads: buderus wall-hung
HVAC Heating & Cooling Buderus GB142 adjusting for heating room via air handler Oct 23, 2011
HVAC Heating & Cooling Burnham MPO-IQ versus Buderus G125BE Oil Boilers Mar 29, 2011
HVAC Heating & Cooling deactivate buderus hot water tank Oct 21, 2010
HVAC Heating & Cooling odor from direct vent Buderus boiler Jun 10, 2007
