Buderus Logano G115 boiler showing "burner error"
Discussion in 'Boiler Forum' started by Pickngrin, Oct 23, 2011.
  1. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    We've got a Buderus G115 that was installed shortly before we moved in a few months ago. My wife noticed this evening that we lost hot water and when I checked the boiler, the display showed 'burner error' and the [incorrect] time was flashing. As per the manual, I pressed the reset button, but that did nothing. I put in a call to the tech that has serviced this house in the past and he suggested that I shut it off for 5 minutes and then try again, and told me to call him back then. I left him voice mail, but I'm wondering if there is anything I can do to manually run hot water in the meantime (it's Sunday evening and I'm not expecting a call back at this point). The owner's manual seems to be pretty vague about these error codes. I also switched it to manual mode, as per the manual, but I'm not sure what that does.
    Anything I should check for?
    Thanks
  2. Pickngrin
    Pickngrin Member
    Sep 5, 2005
    Massachusetts
    Update: I realized that there is an additional reset button at the bottom of the boiler. Pressing THAT one (as opposed to the small green reset button under a cap below the display) got me up and running again.
Similar Threads: Buderus Logano
Boiler Forum Buderus Hot Surface Ignitor Feb 6, 2017
Boiler Forum Buderus G215 with baffles removed Sep 9, 2016
Boiler Forum Buderus set up, wood boiler. Nov 21, 2015
Boiler Forum Buderus GB 142-30 Nov 5, 2015
Boiler Forum Buderus gb142 revision air vent leak Aug 31, 2015
