Bryant evolution Power usage
Discussion in 'HVAC Heating & Cooling' started by The Rich Dude, Sep 29, 2012.
  1. The Rich Dude
    The Rich Dude New Member
    Feb 4, 2010
    Vancouver, BC
    Hey everyone, is there anyway or anyone that could let me know what my 2 stage Bryant Evolution 3 ton and 2 ton heat pumps use for power when running? I can't seem to find this info anywhere? And and all help would be greatly appreciated!! Thanks for your time.:p
  2. jadnashua
    I'm assuming you have an electrical meter? With as much as you can turn off, count the revolutions of the meter while they're on, individually, if you can. The scale will be printed on the meter. Now, if you have a newer, hi-tech meter, you may not be able to do that.
    But, the data plate (likely underneath the access cover) should show what they draw. You'd need to add in whatever the air handler used as well, and if it needed auxilliary heat, those resistance heaters can really add up. One thing to keep in mind, if you try to do a significant setback overnight, because of the amount of heat needed to bring the house back up to temp (verses what it takes to just keep it there), you may find that it costs more to set back than it would to run the thing at a more constant temperature...if aux heat is triggered, the heat is a 1:1, not some multiplier of the heat pump that could be 3:1 or so. The duration and size of the setback would determine whether it's cheaper to just go stable, or keep setting back.
  4. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    In a place as warm in winter as Vancouver I'd disable the aux heat strips and use a programmable thermostat with some smarts that can anticipate how soon it needs to start to hit the setpoint at the desired time. Heat loads of decently tight, small to mid-sized houses are usually well within 3 tons, often under 2 tons. (The 99% design temp for Vancouver is only about -5C.) Recovery ramps might be a bit slow on deep setbacks without aux heat strips, but the efficiency is much higher.
Similar Threads: Bryant evolution
HVAC Heating & Cooling need help - Bryant Evolution Hi Therm Cutout Nov 8, 2013
HVAC Heating & Cooling Bryant Evolution Control Jun 30, 2013
HVAC Heating & Cooling Bryant Evolution proprietary thermostat wiring May 1, 2013
HVAC Heating & Cooling Another Bryant Evolution Question Jul 9, 2010
HVAC Heating & Cooling Bryant Evolution Question May 23, 2010
