bronze fittings and copper fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lmei007, Feb 9, 2012.
  1. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    when will you use bronze fittings, such as cast bronze tee, when will you use copper tees in a copper pipe hot water heating system?
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Check my reply on the ridgid forum as i am not going to retype it all here !
  4. jimbo
    jimbo Plumber
    [h=2]By the magic of cut an paste, here is jerrymacs dissertation!
    For DIYfun, you may be confusing wrot copper or cast copper fittings, with brass , or bronze. No problem using ANY of those. Brass is more expensive, bronze fittings are not readily sold in this market and would be VERY expensive.
    [​IMG] Re: bronze fittings and copper fittings[/h]
    you have your terms mixed up, plumbers do not use bronze pipe fittings they use " brass " fittings
    if i am running a copper water system then i use all copper fittings
    but if you are talking about a hydronic heating system then i might use brass fittings
    the main difference between the two is cost as the brass cost more
    on the other hand if i was trying to finish a solder job and all i had was brass fittings then i would use them rather then taking time to go get copper fittings
  5. MASTERPLUMB777
    Aug 6, 2007
    Texas
    Thank you JIMBO
    for the assit should of thought of that myself
  6. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    The cast bronze is the label I copied from Lowes.
    I found all the tees in my existing hot water heating system are "cast bronze". I noticed those "cast bronze" tees are more expensive. The copper tees are easier to solder and cheapier. So I was thinking there must be a reason for a plumber to use hard to handle and more expensive fittings.
  7. hj
    quote; So I was thinking there must be a reason for a plumber to use hard to handle and more expensive fittings.
    Not really. He may just have them handy, and some specific hydronic fittings only come in cast brass/bronze. Just because Lowes CALLS them cast bronze, does not necessarily mean that is what they are.
  8. ballvalve
    Dec 28, 2009
    northfork, california
Similar Threads: bronze fittings
Plumbing Forum, Professional & DIY Advice Matching Delta's "Venetian" Bronze finish and water filter systems.... Jul 17, 2012
Plumbing Forum, Professional & DIY Advice Ball Valves - Forged Brass vs Forged Bronze Jun 11, 2011
Plumbing Forum, Professional & DIY Advice Sink drain rough-in... to 1960's era male threaded bronze? Aug 2, 2010
Plumbing Forum, Professional & DIY Advice Brass or Bronze Oct 24, 2009
Plumbing Forum, Professional & DIY Advice confusion with copper, brass and bronze Jan 9, 2008
