Broken water supply to house
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PKO, Nov 26, 2012.
  1. PKO
    PKO New Member
    Nov 26, 2012
    Rowland Heights, CA
    From the water meter, I have a 1" PVC pipe which is connected underground to a copper pipe leading to our house. The PVC male thread which attaches to the copper female thread has cracked causing a leak. The male connector is gray leading me to believe it is schedule 80. I would prefer not to use another threaded connection and have read several posts on this subject. I am interested in a Dresser-like connector with bolts to tighten but am not sure which specific one to purchase.
    1) Are the brass or plastic compression couplings available at Home Depot good enough or should I try to find a Dresser type one with bolts?
    2) Can anyone recommend a specific coupling to purchase?
    3) Would it be better to attach a brass threaded nipple to the copper female to allow connection, per HJ, or would it be better to just cut off the copper female and connect to the copper pipe?
    Thanks,
    Pat
  2. hj
    If you want to make your job DIFFICULT, cut the female off and try to connect the PVC to the copper pipe. Make you life simple and use the brass nipple and almost any compression coupling to join the brass and PVC.
  4. PKO
    PKO New Member
    Nov 26, 2012
    Rowland Heights, CA
    I went to Home Depot, Lowes, Ace and Ferguson's. Because the OD on the PVC pipe and copper pipe are not the same, I could not find a compression coupling that would work. If it fit on one side, it wouldn't fit on the other. None of the employees had any other ideas but to go back to the PVC male adaptor. Does anyone have specific names of couplings that would work?
  5. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    You need to reread the part about using a brass nipple then the pipe is the same as the pvc pipe and use a brass "g" coupling to connect
  6. PKO
    PKO New Member
    Nov 26, 2012
    Rowland Heights, CA
    Oh yes. Forgot about the nipple. Back to the store.
  7. hj
    quote; If it fit on one side, it wouldn't fit on the other.
    THAT is what would have happened if you cut the female off the copper. That is also why I said doing that would make your life miserable.
  8. PKO
    PKO New Member
    Nov 26, 2012
    Rowland Heights, CA
    hj & MACPLUMB 777,
    That's why we're here on the forum to get help from pros like you.... To keep from shooting ourselves in the foot. :)
    Thanks for your help.
  9. hj
    quote; To keep from shooting ourselves in the foot. :)
    Unfortunately, many people ask the right question AFTER they have shot themselves in the foot. It is caused by not stopping before you reach your "level of incompetence".
  10. PKO
    PKO New Member
    Nov 26, 2012
    Rowland Heights, CA
    Here's the finished product. No leaks so far. The plastic thread broke in the copper female. It looks like they used PVC cement to screw in the male fitting. I used a torch to heat up the PVC, got a small screwdriver to wedge between the PVC and the copper female. Then I stuck needle nose pliers into the space and gave it a few turns and it came out.
  11. hj
    quote; The plastic thread broke in the copper female.
    They ALL do, well maybe not ALL, (yet), but a great many do. That is where I expect to find leaks, either at the house or at the meter. A plastic male adapter is the "weakest" fitting made. Threading reduces the wall thickness so they have ZERO tolerance for stress or flexing, and therefore they crack.
  12. Terry
    Aug 17, 2004
    Imagine if they spent a few pennies more, how much labor every year would be saved. You almost never see PVC broken anywhere else but at the end fittings.
    Would consumers spend that little bit for a stiffer fitting. I know I do for other plumbing supplies. For instance, I don't carry galvanized nipples on the truck, it's all brass.
  13. wraujr
    wraujr Member
    Sep 24, 2007
    MD
    Do you think its a coincidence that 1"PVC and 1" Brass Nipple both have an identical OD of 1.315"????
  14. PKO
    PKO New Member
    Nov 26, 2012
    Rowland Heights, CA
    Well, I can assume our tract home builder didn't want to spend more pennies than they'd have to. Our home is 25 years old. Makes me wonder what else is going to go wrong......
  15. Terry
    Aug 17, 2004
    You can't blame the builder on that. It's just what it is. They "don't" make a better PVC male adapter.
    I built a few homes, and found that the profit margin was very slim. Nobody is going to pay 20% to 30% more for the same home with quality upgrades that they don't see or understand. I did that one the first one, and nobody understood what I was doing. I was just thinking out loud about what if they did make say a $3 male fitting instead of the 79 cent one. Would the plumbing shops stock them?
  16. big2bird
    big2bird IBEW Electrician
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    We have the same issue in electrical. I never use them in poured in place concrete work. The finishers walk around spreading concrete, and if they step on one, it's broke.
  17. hj
    quote;
    It is NOT "coincidence" it is because they are both made to pipe standards which means ALL "schedule" pipes have the same outside diameter to make them compatible with fittings. The various pipes will NOT necessarily have the same internal diameters, however. The same applies to "CTS/copper tube size" PEX, CPVC, PE, PB, etc. which means their o.d. is the same as copper, even if the i.d. fluctuates according to the wall thickness.​
  18. hj
    electrical
    quote: We have the same issue in electrical
    I was doing the plumbing, a friend was doing the electrical, and another friend was doing the brickwork on a warehouse years ago. The electrician installedl the boxes and conduit between them as the brick courses were laid. After so many courses, they dropped rebar into the block cores and grounted the cells. Every so often the rebar would get "stuck" so they bounced it and then it dropped in. When the electrician tried to fish the wires through the conduits, it would not go. It turned out that the rebars were hitting the conduits and when they bounced it, they broke off the PVC pipe and filled the conduit with grout.
  19. big2bird
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    Yep. Been there, done that. Have to run it surface mount to repair it. Best to use female adapters with chase nipples. Almost as strong as the pipe.
Similar Threads: Broken water
Plumbing Forum, Professional & DIY Advice If It’s Not Broken Why Replace It 18 YO water heater on second floor Apr 16, 2016
Plumbing Forum, Professional & DIY Advice Broken cold water shutoff on water heater Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Help: broken water meter? Apr 16, 2014
Plumbing Forum, Professional & DIY Advice Broken water line Sep 8, 2013
Plumbing Forum, Professional & DIY Advice Is my water pressure regulator broken? Apr 9, 2013
