rcav8or
Hi, I have a PVC toilet flange that was set in place before the concrete floor was poured. The outside metal ring was supposed to be able to be turned, but the concrete stopped it from turning. In my attempts to turn it, I cracked it, as well as the PVC flange. I have tile on the floor, so cutting the concrete around it and repouring is not an option. I would like to take the whole flange out, and replace it. My thoughts are to take a Dremel, and carefully cut the flange away from the waste pipe. The flange sits inside the pipe, not on the outside. Is this a feasible way of doing this?
Thanks!!
Roger
Thanks!!
Roger
