Broken threads in faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by filmkid, Oct 23, 2007.
  1. filmkid
    filmkid New Member
    Oct 23, 2007
    Newbie here, thanks for the forum, admins!
    I moved into a new apartment and went to remove the aerator to install my own that couples with my portable dishwasher. As I tried to unscrew it, the threads snapped off due to corrosion.
    I have tried a few things in removing the threads but no luck to far. I bought 'pipe nipple extractors' from Home Depot, but the largest one is just a tad too small to fit in the faucet mouth. I was thinking about trying to wrap a washcloth around it and try that, but I am doubtful.
    I tried soaking in LimeAway and tapping a tiny screwdriver inbetween the threads, but that spelled the end of that screwdriver as it bent and became worthless. I may try an awl next.
    Currently it is soaking in CLR. Does anyone have advice for me? Like I said it is an apartment, and my manager is never going to get around to a replacement faucet, it took me three weeks to get a front door key that doesn't take 20 minutes of jiggling to open the door. Seriously.
    Thanks so much!
    Filmkid
  2. filmkid
    filmkid New Member
    Oct 23, 2007
    soaking in CLR and using an awl to break away at the threads worked. I hope others can benefit form this, since I didn't see anyone post anywhere on the web that they had success w this.
    Oh BTW, I did use my power drill with a tiny titanium coated bit to drill into the threading in various spots. I was very careful not to go too far and damage the faucet threading. Worked like a charm. I had read of ppl trying to hacksaw bits of thread in larger pipe, and couldnt do that w such a narrow/shallow area... but the drill was perfect.
  4. jimbo
    jimbo Plumber
    Congratulations on your ingenuity!
    The scratch awl, or ice pick, is the tool I have used. The hardest part is if you cannot remove the spout, your are working upside down with a mirror.
    By the way, if you put just a light dab of plumbers grease, or even vaseline, on the threads, the aerator will come out easier next time.
  5. filmkid
    filmkid New Member
    Oct 23, 2007
    NOW you tell me! :)
    Thanks! I was proud to tell my building manager I took care of the problem myself.
    Luckily I was able to take the spout off... never would been able to get it myself otherwise, I'm just not that coordinated!
    Thanks again for providing such a site!
    Best,
    fk
Similar Threads: Broken threads
Plumbing Forum, Professional & DIY Advice broken water supply to washer - I stripped the threads! Brand new! Nov 27, 2012
Plumbing Forum, Professional & DIY Advice Rusted/broken threads Nov 19, 2009
Plumbing Forum, Professional & DIY Advice Broken threads on check valve cap Mar 8, 2008
Plumbing Forum, Professional & DIY Advice Broken sanitary tee in block Jan 29, 2017
Plumbing Forum, Professional & DIY Advice How to fix broken bolts from the sewage basin lid? Do i need a new basin? Jan 21, 2017
