Broken sprinkler pipe...
Discussion in 'Irrigation / Sprinkler Forum' started by Lori Stephan Rockey, Apr 25, 2012.
  1. Lori Stephan Rockey
    Lori Stephan Rockey New Member
    Apr 25, 2012
    Florida
    I have a 3/4 pvc pipe that broke right where it connects to the valve. What options do I have to repair the break? Will I need a new valve?
    Any help will be greatly appreciated.
    Thank you,
    Steve in Central Florida
    In the link to a picture of my problem, the valve can be seen in the lower left, the crack runs about 6 inches right up to the crack.
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Why would you need a new valve?
    A coupling and threaded adapter and short chunk of pipe and done.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
  5. Lori Stephan Rockey
    Apr 25, 2012
    Florida
    How do I attach the coupling? The old one is glued in and the pipe is broken right up to the coupling.
    srockey
  6. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    Use the Ram-Bit to cut the pipe out of the valve. Then glue in your new fitting and pipe.
    John
Similar Threads: Broken sprinkler
Irrigation / Sprinkler Forum Need help to fix broken copper tubing Nov 7, 2015
Irrigation / Sprinkler Forum Broken part? Please help :( May 7, 2014
Irrigation / Sprinkler Forum Two problems - controller leaking, underground pvc broken somewhere Apr 20, 2012
Irrigation / Sprinkler Forum I have a broken Hunter head...Help Jun 20, 2007
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
