Broken sink stopper knob
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by maddfrog, Sep 5, 2006.
  1. maddfrog
    maddfrog New Member
    May 19, 2006
    California
    I have an old Delta single handle bathroom faucet. The knob that you pull up to stop the sink broke in half, so I'm left with a smooth metal rod sticking up. Can this part be replaced? If so, where might I find one? The faucet came with the house and is probably about 15 years old.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Contact Delta and they'll send you this part at no cost to you. Otherwise this part is commonly found at big box stores or plumbing supply houses but you usually have to buy the entire linkage w/pop-up drain.
  4. maddfrog
    maddfrog New Member
    May 19, 2006
    California
    Thanks
    Thanks, Rugged. I was hoping for an easy solution. The bathroom is slated for renovation next spring or summer and the faucet will go, so I was hoping to spend little or nothing. This fits the bill...
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    If you know any plumbers or maintenance men, they'll have just a replacement rod. If you have a Ma and Pop hardware store, they might have just the rod. If not, you have to buy the whole pop-up assembly to get it. Or, you could just remove the stopper from your sink entirely and just go without one. That would be the cheapest way to go.
Similar Threads: Broken sink
Plumbing Forum, Professional & DIY Advice kitchen sink pluged/glued/broken cleanout Apr 20, 2015
Plumbing Forum, Professional & DIY Advice Bathroom Sink Drain (Broken from wall to Ground) Jan 11, 2009
Plumbing Forum, Professional & DIY Advice Broken Sink Sprayer Jan 8, 2007
Plumbing Forum, Professional & DIY Advice Broken sanitary tee in block Jan 29, 2017
Plumbing Forum, Professional & DIY Advice How to fix broken bolts from the sewage basin lid? Do i need a new basin? Jan 21, 2017
