broken shower PVC drain pipe
Discussion in 'Shower & Bathtub Forum & Blog' started by natequinn, May 6, 2005.
  1. natequinn
    natequinn New Member
    May 6, 2005
    I'm replacing my shower tub on my 35 year old house. The PVC drain runs under my 5 inch thick concrete floor through a 1 ft square opening. Deep under (about 1 1/2 going to the right side) is the main drain pipe connector. Somehow because of age the pvc pipe broke from the t-connector. Is there a simplier way to remove, replace, connect the pipe again to the t-connector? Or should I have to remove some of the concrete floor to widen up and get easy access to the t-connector on the side? Is there a chemical or solution to remove the old glue to that connector? Any advise I can get? Anything...
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    PVC "glue" chemically causes the surfaces of the pipe and fitting to briefly melt and then fuse together. It is very similar to metal welding. It is very difficult to remove a fitting from a PVC pipe without damaging the pipe. The PVC did not break because of age. Something caused it to be stressed. The first PVC that we used years ago was much thinner and therefore much weaker than present day, so it would not have had to be too much stress to cause it to break. The only proper way to repair it is to access the pipe beyond the break and put new pipe and fitting in. If that means breaking the concrete out, that's what you will have to do. Usually there are no shortcuts to doing a good repair.
  4. hj
    pipe
    A plumber would either "peel" the old pipe out carefully without damaaging the fitting or use a "RamBit" to drill the broken piece out.
Similar Threads: broken shower
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Stripped Screw & Broken Extractor - Shower Faucet Jul 17, 2016
Shower & Bathtub Forum & Blog Shower diverter broken! Need help identifying model. Danze "Parma" Jul 30, 2013
Shower & Bathtub Forum & Blog Shower handle stem broken Oct 9, 2012
Shower & Bathtub Forum & Blog Shower handle stem broken. Mar 25, 2010
