birchlake
Was walking by a neighbor's house when I smelled the faint smell of septic. The owner of the house was outside and I told him about it, we walked around the yard and found that a 4" white PVC inspection port located on the far end of a typical mound system had been cut off with the lawn mower. Ground was moist in this area and the grass was not surprisingly much greener!
While we were standing there talking about it, the septic tank pump kicked on and effluent water bubbled about 4" or so from the top of this port onto the ground for a short period of time until the pump stopped.
Obviously this is an imminent problem that needs attention ASP. At the very least, the cap for this inspection pipe needs to be replaced to prevent further effluent leakage, but my question is this:
Is it normal for this amount of effluent to pump out of the top of a broken inspection port (level with ground) at the end of a mound system?
System is about 3 years old; was installed when house was built and has not yet been pumped.
I told the owner to call his septic designer/installer. Doesn't seem normal for me for effluent to exit an inspection port, but it might be so thought I'd run it by you guys for your opinions.
