Broken Pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by flightline23, Sep 6, 2008.
  1. flightline23
    flightline23 New Member
    Sep 6, 2008
    I bought a home that was built in 1971 last year. I used the warranty that came with the home last week when my garage and kitchen filled with water. The Plumber said it was the water heater and replaced it. there was a drain hole in the floor which was covered by a new drain pan that the plumber said was spec. Apparently my pipes are also stopped up according to plumber #2 that came out. Both plumbers told me not to worry about the drain pipe but I am worried that next time something clogs up water will once again pour into my house. Is there a way to seal this is approx 2 1/2 to 3" in diameter and appears to be an old metal rusted pipe broken off at the slab. My plan is to elevate the new heater on a 12" high platform so I can get to the drain. But I am unsure how to seal it off. Any advice would be helpful.
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Why would you want to seal this drain pipe?(I'm assuming its a floor drain)
    I would think that you would want the floor drain to be operating/draining any water that falls on the floor.
    HD carries "flood check valves" that you place in the opening that lets water in, but stops water from backing up into the room
  4. hj
    You are thinking backwards. The drain pipe is already "plugged up", that is why you had the flood when the water heater leaked. The water did not come up OUT of the pipe. The plumbers told you wrong. You should have been concerned about the pipe, and they SHOULD have cleared it out before they installed the heater.
Similar Threads: Broken Pipe
Plumbing Forum, Professional & DIY Advice Broken ABS pipe behind vanity May 24, 2014
Plumbing Forum, Professional & DIY Advice Clamp-on to Cast Iron, broken pipe. Mar 16, 2014
Plumbing Forum, Professional & DIY Advice Automatic Water Shutoff for Broken Pipe Mar 9, 2013
Plumbing Forum, Professional & DIY Advice broken pipe in deep well? Jul 26, 2009
Plumbing Forum, Professional & DIY Advice Broken water radiator pipe fixed, but produces no heat! Feb 19, 2009
