Broken-off pipe in shower spout
Discussion in 'Shower & Bathtub Forum & Blog' started by glair, Jul 15, 2005.
  1. glair
    glair New Member
    Jul 15, 2005
    flight attendant
    louisville
    Anyone know how to get the broken-off male threaded 1/2 inch pipe out of the female threaded end? Male end was corroded and 1/2 inch stuck inside the pipe.
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    You can buy nipper extractors of varying sizes at a plumbing supply house and possibly from the guys in the orange aprons.
  4. jadnashua
    You could use an EasyOut if you can find one large enough. They make an inside pipe wrench, but I think they only work on larger pipe. An EasyOut is basically a lefthanded threaded tapered hardened steel hunk. You put it inside the hole, and then use a wrench to back it out of the wall like a screw.
    [​IMG]
  5. glair
    glair New Member
    Jul 15, 2005
    flight attendant
    louisville
    Thanks for the suggestions!
  6. plumguy
    plumguy New Member
    Jul 15, 2005
    MA
    You can also try a hack saw blade and carefully cut thru the nipple and pry it out with a thin flat screwdriver. Just be careful not to cut thru the female threads.
Similar Threads: Broken-off pipe
Shower & Bathtub Forum & Blog New bathroom renovation pipe gripe Jan 15, 2017
Shower & Bathtub Forum & Blog Trying to replace shower head without pipe! Dec 12, 2016
Shower & Bathtub Forum & Blog Tub drain trip lever stuck in pipe Dec 6, 2016
Shower & Bathtub Forum & Blog Shower pipe weight load Oct 24, 2016
Shower & Bathtub Forum & Blog Shower replacement, 1.5" to 2" conversion - do I need to replace vent pipe too? Sep 9, 2016
