Broken dryer on washer dryer combo
Discussion in 'Electrical Forum discussion & Blog' started by Kristoffer, Dec 14, 2011.
  1. Kristoffer
    Kristoffer New Member
    Dec 14, 2011
    Dallas Tx
    Hey all - new to the site.
    My roommate has an older Frigidare washer / dryer combo. The house is about 2 years old and is fitted for a full size washer and dryer. When the dryer broke on the combo, she didnt have the money to replace both the washer and dryer so she left the washer / dryer combo and bought a new full sized dryer. The problem is the washer dryer is still hooked to a 240 4 prong. Since there is only one outlet, we have to unplug the washing machine ( the combo ) to use the dryer and vice versa. Since we dont use the dryer on the combo, could I switch the 240 to a 120 so we can just use the 120 plug ?
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    No, not without going inside the washer/dryer combo and isolating the washer's 120V needs, and I doubt you could even get an appliance repairman to do that for you. But if the dryer's problem is only that the drum does not turn, that is a tensioner problem that has let the belt jump off the motor pulley ... and I just fixed that on my own combo unit last week. The problem there is a poorly-designed tensioner that does not run true with the motor pulley. You *might* need a new dryer belt, but an extra spring pulling out on the bottom of the tensioner can resolve the alignment problem ... and you can see all of that by opening nothing more than the 2-screw cover on the back of the dryer (after unplugging it, of course).
Similar Threads: Broken dryer
Electrical Forum discussion & Blog Possible "broken breaker" miswiring kitchen splits Sep 29, 2011
Electrical Forum discussion & Blog Broken swith at ceiling fan??? Sep 7, 2009
Electrical Forum discussion & Blog Wiring a 3 wire 220v dryer receptacle with a 4 wire setup Apr 14, 2017
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Feb 12, 2016
Electrical Forum discussion & Blog Need branch ckt diagram for instllation of washer/dryer for permitting Dec 14, 2014
